Part Recommendations
hbomb
Warren, MI
OK, I just got back from getting an engine diagnostic test done on my 88' GT Mustang and it shows that I need a pick up coil and an ignition module. I'm going to buy these parts and have a guy I know install them. What are some recommendations on chosing which parts are good performance pieces? I would like some good quality stuff. Any help would be greatly appreciated.
Harold
So are you saying you need:
1. Distributer pick-up
2. Ignition module
3. Coil
Why all three? No spark? Weak spark?
The only time my mustang ever broke down besides from my abuse was when the distributer pickup broke. The pickup acts like a crank sensor telling the coil when to fire by sending a signal to the module which then converts it to a signal to the coil, the coil grounds sending spark in which is directed by the rotor to the correct terminal on the cap, then through the wire, then through the spark plug, combustion is made. There is how the TFI works.
The MSD unit is nice but is the exact same as the factor unit except it's pretty billitt alumimum instead of cast and uses berrings instead of bushings. Not really worth the price. You can get an after market module like I did and it increased dwell making for a faster hotter spark. I use the MSD Blaster TFI coil.
