Part Throttle problem on 00 gt
May 6, 2005
40
Part Throttle Problem on Blown 00 gt
My 00 GT is choking when I give it any throttle at all. It won't really even move it chokes so bad.
My tuner can't figure it out. He thinks its mechanical.
The car has forged internals, stage 2 comp cams, ported heads, vortech s trim @ 17psi, paxton air to air intercooler, 04 cobra pumps.
Any ideas? Thanks
I would first check all of your connections to your intake and your supercharger. If you have a loose connection on one of these it will completely choke it. I had this happen on my truck. The FIPK was coming loose near the MAF and I didnt see it causing it to instantly choke and not let me go anywhere.
If its not this than hopefully someone else will be able to chime in.
Did this start with the blower install or did it run OK for a while with the blower? Check your front O2 sensors. Mine just burned out from race gas and the car would hardly run except in cold startup mode or WOT.
I had real bad compressor surge on mine under decel. and cruise control and it never choke from idle-2000rpms. Above 2000rpms the bypass wouldn't let enough air out and the car would buck real bad. You are definitely going to need to upgrade the bypass to fix your surge, so I would start there. Once that is fixed you might be able to pin point the problem. If your tuner didn't help problem solve, then i would get a new tuner.
