  • 1994 - 1995 Specific Tech
Parts came today! yay! (pics) Got a question or two.
  • Thread starter Thread starter Scot_94GT
  • Start date Start date Apr 12, 2005
  • 3
First Prev 2 of 3 Next Last
Scot_94GT
262
Spring Lake Park, MN
Apr 13, 2005
#21
  • Apr 13, 2005
  • #21
So...where do I get good gaskets? Does any parts store carry them, or are they more of a specialty/aftermarket item?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 13, 2005
#22
  • Apr 13, 2005
  • #22
Any parts store "should" carry them or ca get them.
ProKiller
3,064
15
78
PA
Apr 13, 2005
#23
  • Apr 13, 2005
  • #23
Scot_94GT said:
Other than their tech support's lack of product knowledge, I'm pretty satisfied with Summit. Fair prices, got my order right, fairly promt delivery...they even threw in a free hat!
are you pointing to the hat or your use of the force levitating that tool box above your head?
those bolts should work, but make sure you check them a couple times after they heat up and cool down. they need to where in. re-torque them down a few times and you shouldn't have any problems.
1slow95
1,797
ohio
Apr 13, 2005
#24
  • Apr 13, 2005
  • #24
I got a free hat with my order the other day. Even got a $20 off code too!
Caldwell
528
Ontario Canada
Apr 13, 2005
#25
  • Apr 13, 2005
  • #25
Hehehhe
sorry man! I couldn't resist.
congrats on the purchases though...
hope the new clutch works wonders.
mine sucked
91LX_5L
1,943
British Columbia
Apr 13, 2005
#26
  • Apr 13, 2005
  • #26
make sure you get some good gaskets, those bbk ones are ****. i suggest fel-pro or motorcraft.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Apr 13, 2005
#27
  • Apr 13, 2005
  • #27
Caldwell said:
Hehehhe
mine sucked
AAAAAAAAAAAAAAAAAAAAAAAAAAAahahhahahahahaha
Scot_94GT
262
Apr 13, 2005
#28
  • Apr 13, 2005
  • #28
Caldwell said:
Hehehhe
[THUMB]http://home.cogeco.ca/~dcaldwell25/disney2.jpg[/THUMB]
mine sucked
oh man... I hope I don't become the next star-wars kid
So basically the gaskets are the same dimensions as stock (I'm at work so I can't compare)...I thought maybe tey had larger port sizes or something for the better headers...but I guess that don't really make sense.
Soo, you hade the King CObra clutch and si sucked? Did it just go bad after a while or what?
Caldwell
528
Ontario Canada
Apr 13, 2005
#29
  • Apr 13, 2005
  • #29
my t.o.b. f'd up a second time, and the shop said that they had replaced it from the original. it was a big mess that ended up having me go to another shop and install another clutch because the bozo working at the first place made me feel uncomfortable with having him work on my car.
the 2nd one works great
the good ol' star wars kid
Hmmmmmmmmmmmmmmmm
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Apr 13, 2005
#30
  • Apr 13, 2005
  • #30
Caldwell said:
Hehehhe
mine sucked
I needed that.
mootang
907
texas
Apr 13, 2005
#31
  • Apr 13, 2005
  • #31
call summit one more time and order some locking header bolts. I got the Breslin ones and they work great.
Caldwell
528
Ontario Canada
Apr 13, 2005
#32
  • Apr 13, 2005
  • #32
wytstang said:
I needed that.
Here to help man, long time no see wyt
how's the injury comin along??
94gts
873
Carmel, New York
Apr 13, 2005
#33
  • Apr 13, 2005
  • #33
bahahahahah those hat pics are hilarious
disney....yaaaayyy!!!
WhiteStallionGT
465
Northern VA / VT
Apr 13, 2005
#34
  • Apr 13, 2005
  • #34
HAHAHAHAHAHAHAHA
Oh man Caldwell, that pic is classic.
Scot_94GT
262
Apr 13, 2005
#35
  • Apr 13, 2005
  • #35
Ok, I got the passenger side header in. had to move the alternator, and jack the engine a little bit to squeeze it in there. Now the bottom side of the header is all scratched up too. I tried the bubble wrap trick, but it just wasn't happening, oh well..I will never see it, so out of sight, out of mind I guess.
I managed to get the front bolt in, but I couldn't get any other bolts in. In order for the holes to line up with the boltholes on the engine, the exit flange of the header hits the floorboards of the car. At first I was worried that they sent me the wrong headers or something (even though the box and invoice were correct), but then I realized that since there is no tranny on, the engine has tipped a bit foreward. So I think I will get the driver's side header in place and install just one bolt too, then reinstall the clutch and tranny, so I will be able to install the header gaskets and bolts when the engine is at the correct angle.
Scot_94GT
262
Apr 13, 2005
#36
  • Apr 13, 2005
  • #36
What exactly is so bad about the BBK gaskets? I know they seem flimsier than the stock ones (there is no metal in BBK's that I can tell, whereas the stock ones seem like they are two layers of gasket material sandwiching a thin peice of sheetmetal). So what does having a flimsy gasket mean for me? Could the gasket blow out?
Since I won't be installing the gaskets until after I have the tranny back in and buttoned up, I will have time to order some gaskets if I really need to.
One more thing... The BBK gaskets have a slightly larger hole for the port than the stockers do. If I get a fel-pro or Mr. Gasket or something, will it have the larger BBK-style hole, or the smaller stock hole?
Thanks.
Scot_94GT
262
Apr 13, 2005
#37
  • Apr 13, 2005
  • #37
Also, I picked up some Bosch platinum 2 plugs. Are they any good? they were $3.99 a pop, so I figured they'd be better than the stock ones. But they have a weird electrode...actually there is 2 electrodes instead of just one. I guess I don't have t gap these plugs?
LoudToy958
435
Bremerton, WA
Apr 13, 2005
#38
  • Apr 13, 2005
  • #38
Thanks.
You just got a great set of headers, get some good gaskets. The BBKs seem to be a big failure item. They just don't hold up. The felpro 1415 are cheap, and work oustandingly well. Even better, if you get the far right, and far left bolt part way in, the Felpros just drop in instead of having to try and line the gasket up with the bolt holes.
Sorry the bubble wrap thing didn't work for you. Worked great for me, but someone told me about it before I took it off. Looks like things are going good for you. The passenger one was the hardest for me, so keep us posted.
mootang
907
texas
Apr 14, 2005
#39
  • Apr 14, 2005
  • #39
actually the bbk gastket has the slits too, so they just drop in. but i still say go to your local auto parts store and order up some felpro's Part #1415.
also i highly recomend some locking header bolts.
rude_life
372
#40
  • Apr 14, 2005
  • #40
I will be doing the same thing to mine in about a week...I really think i need a step by step on this..Do i have to remove the transmission like you did?
  • 3
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
6K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
