Parts list for Turbo Swap????
1992 2.3LX
885
Ky
Needing a list of what at the minimum I need to get this Turbo Swap started.
Already have a 92 2.3L Mustang 5 speed
2.3L Motor
Large VAM (what models did these come on)
Computer (seems that an La3 is preferable)
Does a standard T5 tranny work with clutch and pressure plate for a TC seem to be the best way to go??
Just want to get it up and running then will be doing some more mods slowly as more money comes along.
So my 2.3L n/a tranny will work (for the time being)?
I know it will blow eventually. I just want to get it running and move on from there. When the tranny goes, buy the adapter to run a sbf tranny since they are a dime a dozen, when the rear end goes throw in a 8.8, maybe even do an IRS setup.
I just want to get the thing running and move up from there.
I agree get running first. There is a big learning curve on the turbo. I went from MG's [carb] to turbo [efi]. So that is reason I say that. There is a difference in the 5.0 t-5. If remember correct in input shaft size. I am not real familiar on the t-5 some others may help more. I am running a c-4 behind my 2.3t. Unsure if spoke to you before. I am in central Ky if that helps when you do decide to do it. Best luck Maurice
