I never thought I would have trouble removing a foglight bracket but anyway here's the problem.
First of all, the drivers side all came off in less than 5 minutes but the passenger side is causing some problems. It seems there is something else I'm missing. I'm guessing it is because of the extra bracket material that the 25 lb convertible weight used to be bolted to.
I removed all visible nuts and bolts but the bracket is still hanging on there very tight. I put a pry bar in between the old 25 lb weight bracket and the foglight bracket and bent them apart slightly. This revealed a nut in between the two brackets but it is too tight to get tools in there.
Does anyone have the experience to deal with this or any suggestions?
