  • SN95 4.6L Mustang Tech
Passenger side sits higher after suspension install
  • Thread starter Thread starter R.Shackleford
  • Start date Start date Apr 26, 2007
R.Shackleford
  • Apr 26, 2007
I installed dspecs and H&R ss's towards the end of Feb. Also all new poly isos. I've put a bit over 3000 miles on it since, and it's like the passenger side hasn't settled. The rear is a solid 1/2" higher and the front about 1/4". With the drivers side so low the 1/2" on the passenger side is very noticeable.
I'm looking for opinions as to why.
I've thought maybe it's because I've only had anyone else in the car 200-300 miles tops, so the springs & new isolators haven't fully settled. But it also seems that would happen under the weight of the car itself.
I got up close and looked at stuff the other day, and everything looks fine. The springs are seated in the isolators, etc. It's kind of annoying, because the drivers side is nice and low and the passenger side still has that gap.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Oct 1, 2007
  • Oct 1, 2007
Bump
R.Shackleford
  • Oct 1, 2007
Well I have many miles on it now, and really no change in the un-levelness. Funny that this gets bumped though, because another Mach owner just installed some H&R springs a couple days ago and reported his car sits un-even exactly like mine.
the98stang
2,408
Clovis, CA
Oct 1, 2007
  • Oct 1, 2007
Spring might be "turned" the wrong way. The "pig tails" have to cover up both holes (where the spring sits)...if it was over shot, they might sit differently. Unless that spring has an isolator installed and the others don't
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 2, 2007
  • Oct 2, 2007
Springs don't really settle. At least none that I have seen.
I agree. Make sure you springs are clocked in properly and double check the insulators.
96GTstang46
142
Seattle, Washington
Oct 2, 2007
  • Oct 2, 2007
+3 lol, well i have done my fair share of spring installs (11 or so by now) and when the98stang talked about "pig tail" and when your putting it in, and your going to bring arm back up, the spring moves alittle and sometimes that damn pig tail moves around and ends up sitting in the wrong spot on the arm.
So i would double check that.. just take the front tire off and look where the pig tail sits so you know if that is the issue... otherwise,
BlueOvalStangGT
2,849
Oct 2, 2007
  • Oct 2, 2007
My car is a 94, and I just realized it did this a couple weeks ago, yet I did the spring install 2 years ago....bad shocks/struts maybe?
stangg01
129
  • Oct 2, 2007
I had that problem on my car too when I installed my springs. The car was 1/8 in. lower on the front driver side and 1/2 in. on the rear driver side.
The fix:
For the front springs, the instructions say to place the pigtail between the two holes on the lower control arm. Originally, I placed them exactly in the center between the two holes. Instead, place the pigtail off-center toward the left hole on the pasenger side and the toward the right hole on the driver side.
Apparently Mustangs are heavier on the driver side up front.
fudleyd
180
Littleton, CO
Oct 2, 2007
  • Oct 2, 2007
This is possible--are they the stockers?
As for the pigtails, I had to mess with mine a bit too in the rear, to get the car level....I didn't realize the pigtails in the back had to both be on the driver's side.
R.Shackleford
#10
  • Oct 2, 2007
  • #10
The fix:
For the front springs, the instructions say to place the pigtail between the two holes on the lower control arm. Originally, I placed them exactly in the center between the two holes. Instead, place the pigtail off-center toward the left hole on the passenger side and the toward the right hole on the driver side.
This sounds good to me... I had reseated the springs shortly after posting this thread. Both fronts are oriented exactly the same with the holes. The rears are set the same on both sides too. It's still strange that I haven't really heard of people having to seat the spring in a way other than what is supposed to be "correct". It sounds like it might indeed fix the problem though.
BlueOvalStangGT
2,849
Oct 3, 2007
#11
  • Oct 3, 2007
  • #11
Yeah stock struts with 120k miles on them.
Y
Y2kSlvrVert
22
Cali/LA area
Oct 3, 2007
#12
  • Oct 3, 2007
  • #12
I read that you should NOT cover both holes when you seat the springs as they are designed to allow water to drain thus reducing rust.
the98stang
2,408
Clovis, CA
Oct 4, 2007
#13
  • Oct 4, 2007
  • #13
I believe one hole must be covered.
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
