  • SN95 4.6L Mustang Tech
Passenger Window Alignment - Convertible
  • Thread starter Thread starter RonFromDavie
  • Start date Start date Dec 14, 2006
R
RonFromDavie
  • Dec 14, 2006
I've got a 2001 GT Convertible and the aft corner of the passenger window is hitting the ragtop and I can only close the door properly by lowering the window a quarter inch. It seems the aft end is going up too high.
I'm very handy and wonder if this is something I can adjust inside the door?
MT1083
1,033
Charlotte, NC
Dec 15, 2006
  • Dec 15, 2006
when did it start? You didn't just put on subframe connectors did you?
T
tradde
94
Pennsylvania
Dec 15, 2006
  • Dec 15, 2006
My 2000 does this too, but on the drivers side. I am not the original owner, but it's
done this since I have owned it. I wouldn't even say I have to have it down 1/4"
but even 1/8" works.
BPMWare
10
  • Dec 15, 2006
Window Stops
I recently did some work on the driver's window of my 98 Coupe with power windows and I'll bet your is the same.
If you take apart the door, you'll find two "window stops" that determine just how far the window can go up. It's basically just a 12mm bolt than you can adjust with a socket. On mine, these were adjustable and had about an inch of room to adjust how far up the window would go.
You MAY be able to adjust that on your car to resolve this. I'd suggest checking the haynes manual first under anything window or power door related to see if it mentions the window stops.
The key to remember is that it's sort of a big project because to get the adjustments, you'll have to take the skin, plus plastic lining off. It's important to be careful taking the lining off because you'll need to put it back on. Let me know if you decide to do this and I'll write up my experience in detail.
Take it easy.
M
mlafond
  • Dec 16, 2006
I have a 94 Convertible and I am having the same problem, except the aft end is to low, and causing about a 1 inch gap between the seal and the window which is of course leaking in rain. When I took the door panel off and looked, it appears that the 94 models window stops are non-adjustable, and I was wondering if anyone else has any experience or knows something I can do to bring the end of the window up about an inch.
Thank you
I
Got my first and the top doesn't line with window
  • indy86
  • Dec 22, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 23, 2024
indy86
I
R
Convertible top not closing
  • Ray _Sleeper
  • Jun 27, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 27, 2025
Ray _Sleeper
R
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
Y
Resolved 2011 GT Passenger Window issue... weird
  • YFinder
  • Apr 25, 2024
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 25, 2024
YFinder
Y
W
2012 Base Convertible Driver Side Power Window Will Not Work
  • wmmihail
  • May 25, 2024
2K
2010 - 2014 Specific Tech May 25, 2024
