Passenger Window problem
rocafella99
28
Hey guys. I was having a problem with my passenger window going down it originally wouldn't go down with the passenger side switch but WOULD go down if pressed on the driver side. Now I got a new passenger side switch and it rolls down and up when pressed by it. But if im in the drivers seat and try to lower it I cant unless i reach over to the passenger side and lower or raise. Anyone know what can be wrong?
Replace the driver side switch. It couldn't be ground since the passenger side switch uses the same ground. Check the pink wire for 12v. Push switch to down position, check red/black wire for 12v. Push switch to up, check yellow/black wire for 12v.
