Passenger Window Won't Roll Down
Wildmangodby
Hey guys! I'm new to this forum and I'm in a tight spot. The other day my passenger window just randomly went out neither switches are working and no sound is comin from the passenger window motor. I checked all the fuses and they were fine. I'm assuming it's the motor but I don't want to buy a motor take apart the door panel and be in a more tight spot. Any help? Thanks -GG
So both driver and passenger switches for the passenger window won't bring the window down? Best thing I can tell you to do first is take a volt meter and test both switches to see if they still have power getting to them. If they test to work, then you know it is a window motor issue.
The best way to test this is to take the door panel off, unplug the window motor and check for power there when activating the switch.
