PC carnage pics
  • Thread starter Thread starter 1slow95
  • Start date Start date May 4, 2006
1slow95
1,797
ohio
May 4, 2006
  • May 4, 2006
In case y'all don't know, I work at a computer repair business so I see all kinds of interesting computer problems. This one is definitely the worst I've seen as far as physical damage goes. The pics are pretty much self explanatory, but I will say in the first pic the only thing I had done is remove the cover.
Notice the discoloration on the left side from heat. There's one chip blown you can see there, and the one below that is almost de-soldered from the board. If you look at the CPU socket, you can see where the clip for the heatsink broke off. Im just wondering how long these people ran it with no heatsink before it finally fried...
Side note, my web server is down so Im hosting these pics from home, so they may take a while to load.
Blackened302
1,439
South TX
May 4, 2006
  • May 4, 2006
ouch
gcomfx.com
3,690
Republic, MO
May 4, 2006
  • May 4, 2006
I like the videos on the net of the chips overclocked and popping off the board.
Z
zZsKyZz
503
May 4, 2006
  • May 4, 2006
That's what you get for overclocking without water cooling..
MysteryMachine
1,835
Parkesburg, PA
May 5, 2006
  • May 5, 2006
damn how you do that
SM0k3
580
La Palma, California
May 5, 2006
  • May 5, 2006
wow ive been a tech for YEARS! and ive never seen physical damage THAT bad....on a CPU atleast. lol
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
May 5, 2006
  • May 5, 2006
The flux capacitor must have defibulated.
HISSIN50
34
129
May 5, 2006
  • May 5, 2006
Hey, I like the satelite photo of the little city you took. (that's what it looks like to me at 3 am).
Kinda related (if you dont mind): I have been meaning to download one of those CPU monitoring programs (for temps). Do yout think those are useful?
And is there anything that an idiot can do to improve cooling? I try and keep the vents for the fans and the area around the tower clean (I need to put something like nylons over the vents maybe - it would act like a little air cleaner).
Any easy things one can do to help the machines out?
MysteryMachine
1,835
Parkesburg, PA
May 5, 2006
  • May 5, 2006
if they get too hot ain't they "suppose" to shut themselves off? I know my old PC in teh summer tiem if I leave it on and it gets hot it makes a annoying beeping sound. I used to just let it beep haha guess I better not now
N
Nagash01WS6
402
Deland, FL
May 5, 2006
#10
  • May 5, 2006
  • #10
Intels do, AMD's dont.
1slow95
1,797
ohio
May 5, 2006
#11
  • May 5, 2006
  • #11
No overclocking on this one, that's what happens when you buy an E-Machine! And that's not my pc, I work at a computer shop and somebody brought it in for repair.
HISSIN, CPU monitoring programs are nice for overclocking where heat is a big concern. For your average machine, they're kinda pointless unless you're just curious what your temps are. If you're having lock up/random rebooting issues you could use a monitoring program for troubleshooting.
For improved cooling, add fans. 80mm is the standard case fan size, I have 3 in my machine. One on the front, one on the side cover, and one on the back. Or you could just remove the side cover for a quick easy fix.
HISSIN50
34
129
May 5, 2006
#12
  • May 5, 2006
  • #12
I dont even know what overclocking is, so maybe I'm alright.
I might DL one of those programs just to see what it says though. Thank you.
1slow95
1,797
ohio
May 5, 2006
#13
  • May 5, 2006
  • #13
Depending on your CPU, anything below 50*C is good. 50*C and up, and you could start running into heat related problems.
Basically, the CPU speed is determined by a clock multiplier times the bus speed, so 200mhz bus and 11 clock multiplier equals 2200mhz, or 2.2ghz speed. Overclocking is changing one of those numbers to increase the total speed. I have my machine currently at 210mhz bus x 11 for 2300mhz. It's free HP for my comp.
M
mackey
1,284
Beverly, Massachusetts
May 5, 2006
#14
  • May 5, 2006
  • #14
It took my old AMD XP literally 5 seconds to fry without a Heatsink.
Unknown Connector, 89 2.3
  • 4cylredfox89
  • Feb 1, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 3, 2024
4cylredfox89
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
Betty white budget build
  • Stevenmverrill
  • Jun 16, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2023
2Blue2
95 GT getting Trickflow upper engine kit and more after 20 years parked, help required.
  • newfiestang
  • Oct 18, 2022
  • 1994 - 1995 Specific Tech
4K
1994 - 1995 Specific Tech Nov 22, 2022
96pushrod
D
Electrical 93 LX Fuel Pump Issues w Relay & Fuse Link
  • diesel farmer
  • Nov 22, 2021
  • 5 6 7
18K
Fox 5.0 Mustang Tech Dec 19, 2021
diesel farmer
D
