pcv doesnt look like it will fit!!
  • Thread starter Thread starter old_blue
  • Start date Start date Jul 17, 2004
old_blue
1,783
282
124
Jul 17, 2004
  • Jul 17, 2004
I bought a fram pcv valve and it has a 90 degree elbow attached to it with 2 outlets. Bascially, it looks nothing like the one on my car already. Does that elbow just come off and the rest slides into the hose? I havent opened it yet incase i have to take it back.
The Shape
2,224
East ARKANSAS Delta
Jul 17, 2004
  • Jul 17, 2004
I have ran into that same thing before. Yep you can just pull the rubber elbow off.
old_blue
1,783
282
124
Jul 17, 2004
  • Jul 17, 2004
kewl thanks for the help and wuick response
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 17, 2004
  • Jul 17, 2004
Be sure it's a good snug fit into the grommet - I've found with anything other than the Motorcraft pcv's, they fit rather loosely in the grommet - which can create a vacuum leak.
The Shape
2,224
East ARKANSAS Delta
Jul 17, 2004
  • Jul 17, 2004
Michael makes a good point. Even though I have just pulled the rubber elbow off and used the metal pcv valves from the parts store, they never fit as snug as Motocraft pcv valve.
R
ratrapp
510
buena vista,va
Jul 17, 2004
  • Jul 17, 2004
same here i ended up using a motorcraft pcv valve as sometimes the purolator one i was using would fall out and cause a big vacuum leak.
HISSIN50
34
129
Jul 17, 2004
  • Jul 17, 2004
everyone is right on. dont forget to renew the grommet and clean/renew the screen under the valve.
good luck.
old_blue
1,783
282
124
Jul 18, 2004
  • Jul 18, 2004
thanks again for all the replies, the fram one i used fit snug but I think i am going to go to ford and get the whole setup (grommet,screen, valve) so it will all be new like.
HISSIN50
34
129
Jul 18, 2004
  • Jul 18, 2004
sounds like a plan. do it once and forget for 2 years.
blackstangt
460
ny
Jul 18, 2004
#10
  • Jul 18, 2004
  • #10
it sux that you can only get the screen(element) from ford... I bought a typhoon intake and the rubber part is not staying in, but i have bigger problems and i guess that can wait for silicone or something until later.
The Shape
2,224
East ARKANSAS Delta
Jul 18, 2004
#11
  • Jul 18, 2004
  • #11
Actually you can get the screen at the parts store too. I have bought them at advance before. I would still recomend getting it all from ford though.
BarnStang
1,260
Hagerstown, MD
Jul 18, 2004
#12
  • Jul 18, 2004
  • #12
Yep, in fact, I had my new 92 vert dropped off at a shop I used before. I had my mom pick up a new PCV valve from Autozone and the shop refused to install it for the exact reasons stated above. I had forgot about the fitment problem. Good catch on their part. Something to do when I get home again.
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Which is the correct PCV valve
  • Trogdor
  • Mar 18, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 18, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
