Pcv valve
joeyd0730
130
queens, ny
here is my question. i am running a spyder intake from probe industries. the intake does not have a pcv valve. so what i did was install a breather oil filler cap, and have the air tube from throttle body plugged into the valve cover on the pass side. my drivers side valve cover is sealed. i am noticing some oil on the breather. in your opinion is this the correct way to vent the engine? any suggestions or the correct way to hook it up would be appreciated, thanks joe
Joe, it is hard to beat the active nature of the PCV set up (breathers being passive).
Having oil on the breather can be normal. Do you think you are overwhelming the set-up you have now? If not, while not optimal, I dont see any glaring issues (personally) with your set up.
Others' opinions will probably vary. Good luck.
if it makes a diffrence the baffler is removed on the valve cover so i am hoping this is causing the slight oil on the breather. it is a fresh motor less than i 50 miles on it. just trying to get all the bugs out, thanks for your opinions, and please keep em coming. joe
Oil in the breather in a situation like this is completely normal. There's a great deal of oil vapor inside a running engine as you might imagine. Hot oil (210-270F) is being slung about quite, uh, vigorously. The stock system has a baffle below the intake, as well as an oil trap/screen to help minimize the amount of oil that gets drawn into the system through the pcv valve.
You've got a few options. You could rig up a pcv valve by punching a hole in the valve cover and inserting the proper size grommet/pcv valve and connecting to a vacuum source. If you do that, reconnect the hose from the valve cover nipple to the throttle body -- it let's metered air INTO the engine when vacuum is pulling on the crankcase through the pcv.
Alternatively, leave it plugged, and add another breather to the other cover. This will halve the breathing that's going on through your current breather and help minimize oiling through the breathers. Or - you could put fittings in each cover and run hoses (at least 5/8") to a remote mounted catch can that has a breather on it. Mount the can below valve cover level so any oil that falls out in the hoses can gravity drain to the can. This will move your oiling mess to the top of the catch can instead of having it on top of the engine/valve covers.
If you have to pass emissions and the visual is stringent, the open breathers will be a problem. The pcv system is really part of the emissions control system of the engine.
That will make a difference.
When I still had the TB/VC hose in place and was not using a baffle, the hose was always wet with oil. Once I installed the baffle the hose dried out.
Results may vary, but it made a dif on my motor.
