PCV Valve
nero6
94
I have been trying to track down my surging idle issues and was checking out all of my vacuum lines making sure there were no leaks and noticed that there is no vacuum line hooked up to the PCV valve. I know there is suppose to be a vaccum line running from the upper intake to the PCV valve, but this is where I get confused. The valve cover has a spout on it, that has another PCV valve in it (attached picture) and is attached to a vaccum line leading into the upper intake. The valve cover on the other side has a breather on it (attached picture). Is this hooked up wrong or can I just leave the PCV valve in the upper intake and plug it?? Since its not a stock intake or valve cover I am not sure what is correct, but the PCV valve just sitting in the upper intake with nothing connected to it, can't be correct...
You've got something of a wierd set up there but the basics are that you should have a vacuum line running from the upper manifold to the PCV valve that fits into a grommet at the back of the lower manifold. This provides a vacuum to the crankcase that keeps pressure from blow-by from building up.
At some other point on your engine you should have a vent that provides fresh, filtered, air to the crankcase. In the old days you had a filter on the breather tube that filtered the air that would then enter the crankcase and then the PCV. On a stock 5.0 setup you have a tube going from the intake tube (upstream of the air filter) to a port on the filler neck.
As long as you have those two components in some form or fashion you should be fine.
As to your idle issue, if you have a K&N or similar exposed filter, make sure that you aren't getting prop wash from the little fan on your alternator - that was causing my idle surge. Basically the extra air blown in from the alternator (or engine) fan can fool the MAF and make it go haywire.
Good luck......
If the cap on the drivers side valve cover is 'vented', then you essentially have a vac leak via the PCV.
Then should I plug the PCV valve that is in the stock location or plug the PCV valve that is on the valve cover and hook the PCV valve back up in the stock location?
If I determine this to be the issue, how did you correct it?
To diagnose - take a piece of cardboard and place it b/t the alt and KandN if the surging stops in about 15 seconds you've got your answer.
If that's the cause then you'll need to fab up something to block the airflow. I was able to clock the MAF so that the prop wash wouldn't directly go into the MAF. But for a short term fix I used a small piece of paper rubber banded to the KandN - real redneck like, I know.
My 5.0 is in my 66 so I didn't have a ton of options, but if I had a Fox, I'd probably spring for a fender CAI - that would definitely keep prop wash from the MAF.
Good luck...
Posted via Mobile Device
There is a small nipple coming off the filler neck on the pass. side valve cover. This nipple should have a hose running to the nipple on the top of the TB.
Then, cap off the vented breather on the driver side valve cover.
You can keep the 2 pcv's if you like, it won't hurt anything, and may even help make the system more efficient.
Good luck...
Thanks, I will give that a try.
Perfect, thanks. Hopefully I can get the breather off the drive side without having to take the intake off, as it is a tight fit, with little clearance.
Correct me if I'm wrong, but he doesn't have the stock valve covers. He has the PCV on the passenger side and a breather on drivers side. I think this system would be ok, but you should still run the manifold PCV back to the intake as well. :shrug:
I've seen many that have a PCV in the valve cover, but its typically on the drivers side valve cover, not the passenger side. It didn't replace the original PCV in the manifold either though.
The problem isn't the location of the PCV and Breather....
The problem is that the breather is open to atmosphere, and any air that is pulled into the crankcase through the breather, is not measured by the MAF meter. This creates what is essentially a vac leak, as the ecu never sees the air flowing into the crankcase.
Ideally, I would not put the pcv right next to the crankcase inlet. This would allow the inlet air to travel right back out the pcv, with out flowing through the crankcase.
The fresh air flowing through the crankcase helps clear out contaminants in the crankcase........
Looks like I will be stuck with the breather on the driver side anyway, until I have a reason to take the intake out. I can't take the breather off without taking off the intake. So I will run a vacuum line from the throttle body nipple to the nipple on the filler neck and cap off the filler neck. Then run a vaccum line from the the upper to intake to the pcv valve for now.
I have a breather and the manifold PCV and so far my car seems to run ok with it setup like that.
I was trying to think of another thread I saw that had a really good diagram posted of the airflow through the engine....not combustion airflow but the pressure. Anyone know what I'm talking about? That's why I commented on the side of the engine that has the breather vs. PCV. But like I said...guess it doesn't really matter.
This is a vac leak. If you install a cap in place of the breather, you should see a difference in how the car idles.
Likely the Adaptive Strategy is able to correct for it, but it is a vac leak...
The inlet air going into the crankcase should be metered by the MAF meter, which is why the stock TB has a nipple on the top of it.
For a simple cheap part, it is confusing as @#$@%. I have read posts on other forums running 8 pages talking about a PCV valve and why you should or should not run a breather with a PCV valve. So I am about as confused as possible, and would change it back to stock if it was not for the intake blocking the breather, just so I can narrow down if that is one of the issues causing my rough, surging idle.
Seriously,
Pull the stupid intake. It is worth the time and gasket set.
