Im installing my rocker arms back onto my car (same ones that were on there a year ago), and am running into a few issue...
Im following cranes instructions (http://www.cranecams.com/pdf/453e.pdf) on how to make sure there properly adjusted, and im having a hard time finding what stroke is the compression stroke. It says
"When both pushrods are at their lowest point and appear to be at an equal height, you are in the correct position to install the cylinder's rocker arms. This will occur when the cylinder is at top-dead-center, on its compression stroke."
now is it refering to when the pushrods are both at rest, and not moving at all when you turn the motor over by hand... or when the pushrod is coming down and the other starts to move up, they hit the same height?
Also, my motor has been sitting for quite some time now, w no oil in it, just freshly rebuilt. It has the assembly grese and thats it. Is it going to matter that the lifters dont have any oil in them? If it does, how do i get them ready for install?
Thanks
BJ
Thanks
BJ
