- Oct 28, 2004
- 116
- 0
- 16
I just got a pedal assy for a T5 swap and things don't look right. Here's some pics. Hopefully someone can identify what year they came out of.
Here's the back side of the new brake/clutch pedals. Note that there are
three holes for mounting studs and one mounting stud is attached.
Here's the front side of the stock 95 single brake pedal. There are four studs mounted to the firewall and the unit attaches with four nuts.
Here's the full frontal view of the new assembly. Notice the white cylinder that goes from the middle of the brake pedal (left side) up. That is the brake switch. The connector for the brake switch is the blurry connector below. Notice that it is small compared to the stock pic that is two pics down.
New brake switch connector.
Old brake switch connector. Also notice the black tube that is just above the connector. This ties into the brake switch as well as a normal mechanical switch.
Can anyone identify what model year the pedal assembly goes to? There is a part number on the new brake switch F6ZC-9C962-BD (1996?) and one on the clutch cruise control switch F4ZB-9F645-AA (1994?) Those are the only markings that I could find. Thanks for any help.
