Pedestal or Stud ?
  • Thread starter Thread starter Ray@VSK
  • Start date Start date Sep 2, 2004
1 of 2 Next Last
R
Ray@VSK
355
  • Sep 2, 2004
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Sep 2, 2004
  • Sep 2, 2004
It's a bit hard to tell with the reflection in the picture but it look's like pedestal to me. Look's like it's a Y 302 GT-40 Head which I believe are designed for pedestal mount.... Some machining could easely solve that so you can use stud's.
Shon
R
Ray@VSK
355
  • Sep 2, 2004
I thought they were Stud ? These heads are GT-40 Y303 Aluminums, I thought the difference between the pedestal & the stud was there was an opening between mounting points for the rockers ?
The GT-40 X303 Aluminums do have a different mounting pattern than the Y303's see below,
maverick0716
3,924
Chilliwack, BC, Canada
Sep 2, 2004
  • Sep 2, 2004
I don't believe any Ford Racing heads are stud mount......don't quote me on that though.
R
Ray@VSK
355
  • Sep 2, 2004
Well as you see in my pictures on is & ones not just don't know wich is wich, any help on this ?
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Sep 3, 2004
  • Sep 3, 2004
pedestal i think.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 3, 2004
  • Sep 3, 2004
The threaded holes dont look large enough for studs. I'm going with pedestal.
R
Ray@VSK
355
  • Sep 3, 2004
Hmm, I thought the opposite, come on someones got to know this, I meen you have to when buying rocker arms
jeffnoel
1,638
Clovis, CA
Sep 3, 2004
  • Sep 3, 2004
If a 5/16 bolt screws into the boss it's a Pedestal.
D
dude5l
201
Grande Prairie, Alberta , Canada
Sep 3, 2004
#10
  • Sep 3, 2004
  • #10
Pedastal.
rd
3,316
63
109
Ocean Springs MS
Sep 3, 2004
#11
  • Sep 3, 2004
  • #11
Literally, you can use either. Pedestal heads will accept the special 5/16 and 3/8 combo studs.
J
Jason@AFR
58
California
Sep 3, 2004
#12
  • Sep 3, 2004
  • #12
Thouroughly agree, 5/16=pedestal, I believe 7/16 is the standard hole for stud
R
Ray@VSK
355
#13
  • Sep 3, 2004
  • #13
The reason I am asking is I'm trying to buy some rockers for these heads but don't know what to get, is there 2 or 3 different kinds of rockers, Pedistal, Bolt on & Stud right ?
Or is Pedistal considered Bolt ons ?
R
Ray@VSK
355
#14
  • Sep 4, 2004
  • #14
ok can someone recommend some roller rockers to use with the GT-40 Y303 Aluminim heads I have ?
Preferrably some that I do not have to replace valve covers to use ?
R
Ray@VSK
355
#15
  • Sep 4, 2004
  • #15
Bump
RYC CUKR
1,437
Orlando
Sep 4, 2004
#16
  • Sep 4, 2004
  • #16
pedistal and bolt on rockers are one in the same. Just different terminology.
T
TheUser
1,859
Springfield, MO
Sep 4, 2004
#17
  • Sep 4, 2004
  • #17
I would assume--and I might be wrong--assembled heads would come with the studs installed. I, however, would use the "bolt" information above and get a 5/16 bolt and see if it fits.
65ShelbyClone
4,675
38
119
Sep 5, 2004
#18
  • Sep 5, 2004
  • #18
Now that I looked at the picture a little closer I noticed the little parallel lines on either side of the bolt holes. Lines that would have been left by the pedestal channels. Guideplates probably wouldnt have done that.
R
Ray@VSK
355
#19
  • Sep 5, 2004
  • #19
Ya I went ahead & bought a set of CRANE 1.7 Roller Rockers, hopefully there will be no valve cover clearance problems, just out of curiosity these rockers should bolt up fine with no valve/piston clearance problems right ?
stangersteve
Central Texas
Sep 5, 2004
#20
  • Sep 5, 2004
  • #20
Hey man i know you've probably already found a answer for your head question. So this is for everybody else. that particular head you cannot use pedestal mounts. A pedestal rocker mount head has a square notch cut out on the mount casting. If you have that then you have to buy a screw in stud conversion kit which fills in the nothch and has a push rod guide on it. There only about $70.00. So you will be just fine buying true rollers as long as they come with studs in the kit, if not you'll just have to buy them according to the thread size.
1 of 2 Next Last
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
Paint and Body Missing windshield molding stud
  • AnthonyA1234
  • Oct 30, 2024
Fox 5.0 Mustang Tech Nov 3, 2024
Mac131
Engine Roller Rocker Stud Size, GT40P heads
  • foxbodyclark
  • Jan 25, 2025
2K
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
