So i installed BBK LT....
And i do beleive it has leak right at header meets head. when i installed header, i reused stock gasket. but iguess they failed to do its job, so where and what kind of gasket should I get(or should I have gotten befor idid the install)?
i'm thinking one of these Aluminum gasket by Percy's High performance inc(summit part numberPHP-66033) . but i'm not sure whats best out threr. should i go with graphite kind?
That is not going to be fun to replace
It is going to be like doing the job all over again. Good luck I had the SLP that came with gaskets which are not even close to the same as the stock gaskets. Has anyone else installed BBK LT using the stock gaskets with no leaks?
