Performace Packages
  • Thread starter Thread starter STRACER
  • Start date Start date Jul 23, 2004
STRACER
Brandon, MS
Jul 23, 2004
  • Jul 23, 2004
Does any one sell pre-selected performace packages including but not limited to heads, intake, cam, throttle body, injectors.......etc?
There used to be a few companies that did but you don't ever see anyone advertise anything like this anymore.
wildstanggt
186
Omaha, NE
Jul 23, 2004
  • Jul 23, 2004
Holley sells a cam intake and heads combo that is suppose to produce 350 hp together. Both edelbrock and trick flow make parts that are designed (dyno tested) to run together but they sell them individually. Edelbrock's tech support is real friendly you can call them or e-mail them what you want and they can recomend a package for you
good luck
MustangMulch
303
Santa Clarita, CA
Jul 23, 2004
  • Jul 23, 2004
Trick Flow sells a package with twisted wedge heads, stage 1 or 2 cam, street heat or track heat intake, timing chain, and hardened pushrods. I'm not sure if there is anything else in the package, but I know it comes with that stuff. It goes for around $2049 or $2099 depending on which cam and intake you want.
I've heard better things about the trick flow package than the holley package, because supposedly the cam that comes with the holley package is crap. Summit sells the TFS package, and that's definitely the way to go. Most of the numbers people dyno at with the TFS package are around 300-310 rwhp and around 330 rwtq.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
What's it Worth? Considering Selling '82 Fairmont Futura Body Shell
  • DonMay63
  • Apr 5, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Apr 5, 2026
DonMay63
D
A
Old Holley head identification???
  • Ar15cobra
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
AeroCoupe
