performance gains...?
so i am tinkering with the idea of getting a 75 mm tb and MAF adding either a trick flow upper and lower manifold and if money is available a decent set of heads.... I am curious what kind of performance gain i should see... obviously ill be upgrading the injectors while its apart as well. Curious what numbers i should get without the heads and with... hell toss some brand names at me too. I found a guy to burn me a chip as well with my mods.... I dont race the car so please avoid that I just want a snappy street car that I can get my fix for speed when I need it. Right now I only have a CAI and MAC headers O/R H pipe and cat back.... Thanks guys!
I'm all about getting the most bang for the buck spent :banana:
With everything you've done and have talked about ..........
the items to give most power are the intake and catless mid pipe :Word:
If doing a little at a time :shrug:
You'll not see a gain with the meter or tb :eek:
again ... if on a budget
I'd do the intake for a first mod ..........
save up for the heads
AND
If you can swing it ... do a cam along with the heads
Then again ...
a cam along with heads will most likely cause you to need a tune
and
at that time ... you'll push your tiny oem inj's too far :(
so
you gotta plan for how you wanna do the meter/inj/tune thing :D
any-hoo ... you gotta look long term with your plans and goals ;)
that way ... you'll make the most efficient use of your time and money :)
Grady
in the long run..
so in the long run id like to be up around 350 hp or so.. I already have the cats MIA from the exhaust (lovely sounding i might add) and now its time to play with the motor a bit... so some say a trick flow kit and others say save up and pretty much build the whole motor at once. in which case I would probably build a 331 with a good H/C/I set up. My question is will a throttle body and bigger MAF do anything ?? and I may have a holley systemax intake to drop on it real soon from a buddy... some one has to know the answer
A few things to research :D
If you are gonna do a NA combo, go for the additional cubes ... 347 :)
Yes ... upgrade of tb and meter will do something
and
the're a must do thing on a h/c/i combo :Word:
Sooner or Later ... they gotta be upgraded
I'm just saying later ... thats all
I was just trying to show other items will give more gain NOW as opposed
to items like tb & meter
If you can score that intake you can run it just fine with your OEM tb
and meter
You'll run out of fuel before the meter becomes pegged ;)
You gotta decide about how you are gonna tune to deal with the additional
fuel :scratch:
Hosin around with fuel pressure and dizzy twistin ain't gonna cut it for
tuning such a combo :rlaugh:
With a 347, you're gonna need a meter and inj's of sufficient size to feed
such a combo ... so ... decisions about which parts and how to tune will
need to be made but for now ... you need to start the plan/research
thing don't ya know
30's will be on the small side :(
and
36's are no longer available :bang:
therefore
42's might be your only choice :shrug:
You can go aftermarket meter
or
You could go with a lightning meter
anyway ... more stuff for you to think about :)
Grady
yeah I hear you i am trying to figure out which direction to go with the motor... If i do bore it out im going to a 331 thats already decided on. I have a guy who can burn me custom chips for my mods. he said he can even reburn them for $10 when I add more performance parts. I just want to add some pep to the motor to fulfill my need to feel some giddy up once in a while. I guess its time to hit the books whith a pen and paper and then the bank for a loan! hahaha anyone else who wants to chime in with some help lets have it... im open for ideas. My buddy even say nitrous but im nervious about that *****.....:nice:
