for me-it was an awesome investment. mind you, a stock tune wouldnt have changed anything. infact, id tried a SCT chip with a stock tune and it didnt increase horsepower in the least bit. The only advantage youd get from it assuming your car was running in the right a/f(not running too rich or lean), would be calibrating the speedo for gears, turning off the traction control permantly, and bumping up the timing.
dont buy a chip til youve got quite a bit of mods, then stick it on a dyno with wideband so you can see what you a/f is at. In my case, i was running real rich for some reason. I paid 500 for a dyno tune, and we only managed to pick up a few horsepower. Then i took it to another shop(strictly performance), and we did a baseline with the chip(234 peak hp) and without (234). Then we made some changes, got the a/f where the car liked it the best, and the peak picked up to 247rwhp in 99 degree heat-with lots of humidity. But-the best part was around 3800rpm-the car picked up almost 40lbs of torque. After advancing the timing quite a bit, we even took out a couple degrees, because the 2 degrees we added didnt make hardly any difference. Once i get pullies, and my Fipk-hopefully ill be in the 250+ range.
