Performer Air-Gap versus RPM Air-Gap
67topless
203
Raleigh, NC
Anyone got some feedback on the new Performer Air-Gap? I saw it on the Edelbrock website, but can't find an application for it on a Small Block Ford.
http://www.edelbrock.com/automotive_new/mc/manifolds/manifolds_main.shtml
Performer Air-Gap® & RPM Air-Gap® Manifolds
This award-winning design incorporates the same race-winning technology that's been used on our Victor Series competition intakes for years. The air-gap design features an open air space that separates the runners from the hot engine oil resulting in a cooler, denser charge for more power. RPM Air-Gap manifolds are modeled after Performer RPM intakes for high performance street power from 1500-to-6500 rpm, and the new Performer Air-Gap manifolds are ideal for street performance from idle-to-5500 rpm.
Pay no attention to it, it's just another product aimed at the small block Chevy guys(who seem to be easy to fool with the newest "whiz-bang-doo-dads"). Contrary to what Edelbrock advertises, the RPM series manifolds work as well in "off-idle" rpms clear to the limit of the engine's abilities. You'd have to put each on a motor on a dyno to see what little difference there is below 1500 rpms.
The AG is significantly taller and often causes hood clearance issues.
IMO, if you need that much intake, you are better off with a mild single plane intake.
according the e'brock site the performer air gap (small chevy) is only .25" taller than a regular performer and about 3/4" shorter than an RPM air gap. they probably designed it for 2nd gen camaro guys since the rpm air gap won't fit under a stock 2nd gen hood (with any sort of decent air cleaner, anyway), at least that would be my guess.
they don't list the performer air gap for the small ford, yet, but i would imagine the same would hold true for 65-66 mustang guys as well, especially with a 351w
Bad marketing?
I think it is a little confusing (to my pea brain) that they've had a prodcut called the Performer RPM Air-Gap and have now released a new product called the Performer Air-Gap.
:notnice:
My .02 cents...
Thanks bnickel for pointing out that it is a cheby product and not a Ford one... at least for now.
Scott
:notnice:
My .02 cents...
Scott
think of it as the difference between a performer and a performer RPM and then add the air gap in for both of them. i can see how it would get confusing and quick.
the performer air gap (for chevy) is new for 08 while the RPM air gap has been around for a while. i'm guessing the performer air gap for small fords will be released in the next year, they generally experiment with the chevy stuff first and then when/if they decide it's a good design they release it fords and others later.:nice:
I thought that's what I said....windsor...not so good. It's tight with a 351, but it can be done. For more flow put a K&N lid on top if you aren't using an air filter with enough area.
I was offering my own direct experience. It sounded like your direct experience was limited to a 302. 2 years from now, when somebody is searching these threads for info on how an Air Gap fits a 351W, a post that says "I heard that an Air Gap is a tight fit on a 351W" will be of limited value to him.
