Perplexing problem! No start on my first hypo build
  • Thread starter Thread starter kett3023
  • Start date Start date Nov 28, 2005
K
kett3023
philadelphia, pa
Nov 28, 2005
  • Nov 28, 2005
Hey everyone!
Its been a while since i've posted, but im having a problem that I need someone's help with.
Here's my situation:
I've recently reworked a 302. It is .030 over, with flat top high compression pistons. The heads are ported and polished w/ a 1.94 intake and 1.6 exhaust I've got a larger pan with a high flow oil pump. On top I got edlebrock street/strip performance intake with a 600 cfm holly. on the bottom, of course a set of long tube headers. Right now, I am using a Ford Duraspark II system from early 80s 5.0L. The Engine is in with the only the headers.
I am a bit excited to hear her roar!
Here's my problem:
When turning it over, I can get cylinders to fire in the Key Start Position and it almost wants to start. Once I take it from Key Start to Key Run Position, the engine quickly dies. Sounds like to me that the spark stops.
I have re-wired the ignition system to a push button start direct to the starter and ignition control module. I have taken 12 volt from a wire that was 12 volt key on to go to the ignition control module for other wire.
I have tried a new control module with same problem.
ANY IDEAS???? please help, i want drive her!
K
kett3023
philadelphia, pa
Nov 29, 2005
  • Nov 29, 2005
ttt
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 29, 2005
  • Nov 29, 2005
Is the motor getting fuel? I assume so (mechanical pump + engine crank)
With the key in the "run" postion you should have a 12V signal to the coil. Have you verified that?
SQUEEZE&STROKE
SOUTHERN CA
Nov 29, 2005
  • Nov 29, 2005
Checked the timing?
Modular2v
3,222
23
99
oklahoma
Nov 29, 2005
  • Nov 29, 2005
mine did the same thing when i first started mine...timing was off 45 degrees haha
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
