  • SN95 4.6L Mustang Tech
PI headswap first start....BIG PROBLEM HELP!!
  • Thread starter Thread starter 98blackstallion
  • Start date Start date Sep 17, 2005
  • 3
  • 4
First Prev 2 of 4 Next Last
98blackstallion
602
mtn home arkansas
Sep 18, 2005
#21
  • Sep 18, 2005
  • #21
ok guys i looked under the car and here is what I have come up with..I am missing the small plug on the back side of the driver side head...Also i noticed there is oil leaking from the passenger side of the block too...but not in the back more toward the front and I am also seeing water coming from some where too...all hoses are checked and accounted for...WHat the **** is up with this??? Could the gaskets not be sealing? what the hell it doesnt look like the valve covers tho because its not that high up..
98blackstallion
602
mtn home arkansas
Sep 18, 2005
#22
  • Sep 18, 2005
  • #22
oh yeah the driver side head doesnt look like its on the block all the way i mean it looks like the back part of the head hangs off the block..this is some crazy *****
MyEarsHurt
918
#23
  • Sep 18, 2005
  • #23
Who did your install? If the head wasnt on the block right, I dont think the thing would even start...Try to solve one problem at a time here. Is it water/coolant and oil that is coming out of the car or what? Concentrate on the oil leak first, get a new set of plugs and install them in the head, if you can reach from under the car. After that, start checking everything else for the coolant leak, but that should be easy to diagnose where it is coming from. You did get new head gaskets/head bolts correct? Cause you cant reuse the old ones... The bolts actually stretch when you toque them all the way down, so if you try to reuse them, they will be too long
98blackstallion
602
mtn home arkansas
Sep 18, 2005
#24
  • Sep 18, 2005
  • #24
ok i have the intake manifold off and the valve covers and the oil that is in the heads still is mixed with WATER! So now im starting to get alittle worried as to what the hell happened. Could ford have sold me the wrong head gaskets? or what the hell could be wrong I know im missing the little plug in the back of the driver head but theres alot more wrong here and I need all the help i can get..
98blackstallion
602
mtn home arkansas
Sep 18, 2005
#25
  • Sep 18, 2005
  • #25
I did the install very very slowly and took my time doing everything...I found out that the head always looks like that i was just freaking out. Its hard to solve one problem at a time because the car leaked OIL and WATER too..not just oil like i said before...i am about to remove the heads either tonight or in the morning because there ready to ocme off yet again. Yes I got the bolts and head gaskets too because i got the ford head changing kit. But I have found out that somewhere OIL and WATER have mixed together and made cloud **** in my heads. SO I am thinking its a head gasket maybe they didnt give my the right ones??? because both side are doing this one in the back and the other in the front so I dont know we'll find out soon tho..thanks guys.
MyEarsHurt
918
#26
  • Sep 18, 2005
  • #26
Good luck, get the head chaning kit from steeda or something, then you know its the right one. And when you have the heads off get that plug situation taken care of. Too bad you have to take it all apart again. It should be easy the second time around though now that you know where everything goes.
98blackstallion
602
mtn home arkansas
Sep 18, 2005
#27
  • Sep 18, 2005
  • #27
ok guys i have the heads off the car and it record time for me (5 hours without a break) I have found that there is or was a bunch of water in the oil how it got there i dont know As for the plugs i was missing the small one in the back of the driver side head and i was missing the one right on the upper front SIDE of the passenger side head and which both are now plugged and ready to go. When I pulled the heads off there was 1 cylinder on each side that had some rust coloring on the cylinder walls and that concerned me as well as the water in the oil. Im confused guys can anyone suggest what i should do or what?
98blackstallion
602
mtn home arkansas
Sep 18, 2005
#28
  • Sep 18, 2005
  • #28
can those plugs cause water to get in the oil?
98blackstallion
602
mtn home arkansas
Sep 19, 2005
#29
  • Sep 19, 2005
  • #29
anyone
98blackstallion
602
mtn home arkansas
Sep 19, 2005
#30
  • Sep 19, 2005
  • #30
droptop, blev, tomustang any of you guys have a thought about this? i am just looking for help..i dont know about it. I figure water got in the oil from a bad head gasket or something but im not sure.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 19, 2005
#31
  • Sep 19, 2005
  • #31
i dont know which plugs go to what, but you might be having a coolant-to-oil plug mixture, I looked for the online installs/how-to where i did my headswap but their gone.
DropTopPony
Noob Slayer
2,570
south jersey
Sep 19, 2005
#32
  • Sep 19, 2005
  • #32
sorry, i can only give advice for what I have experience with..my swap went rather smooth. sorry bro..I wish I had coolant in my oil to help you out try starting a new thread with the heading stateing your new problem.
Z
zeotide
14
#33
  • Sep 19, 2005
  • #33
The rust color is to be expected from the water getting in the oil.
Not sure if will be a problem or not. I would expect that the rings would just clean it off when the car is started again.
I would guess the stain could be removed safely with a soft cloth, but this is just my knowledge rather than actual doing, so you might want to check with someone else.
The oil plugs by the sound of them are there to cover holes needed to cast the heads or for external connections to the lubrication system. They don't separate coolant and oil.
It sounds like the head gasket didn't seal properly and allowed water to enter the cylinders. If the heads have been checked for flatness then it's something to do with the gaskets or the installation.
While you have the heads off it's probably a good idea to put them side by side and compare. Follow the oil and coolant passages to see if you missed anything else.
Now I know why I haven't bothered to do this modification though.
Blev
1,295
So. Cal. V-Town
Sep 20, 2005
#34
  • Sep 20, 2005
  • #34
WoW.....
I thought I had a hard time with my headswap. I too, forgot the damn galley plugs
I was able to get them in with the heads still on. I don't have A/C anymore, but who needs it when you have a vert and live in Cali. LoL...
Anyhow...
The water was probably from inside the block. When you crack the heads off all the water and oil mixes together into the block. I ran the car for about 500 miles then changed my oil and flushed the radiator. The head will slightly hang off the back of the block, but only about 1/4 of an inch, at least that's about what mine hung off. Since you have torn the block back down, you MUST get new head bolts and gaskets. The head bolts are TTY and the gaskets are a one time use (if they are the ford ones). You can use the timing cover gaskets/seals, valve cover gaskets, and itake gaskets over again. It seems you have it all torn down and the problem fixed, so the rest is cake, you've already done it once. Just take your time.
98blackstallion
602
mtn home arkansas
Sep 20, 2005
#35
  • Sep 20, 2005
  • #35
thanks Blev that makes me feel alittle better about my situation. I never htought about the water getting into the block after i pulled the heads the first time. But i kept the oil drain plug plug out the entire time i did the swap so any thing would run out and nothing ever did. Would the water have just set in the motor without coming out?
Z
zeotide
14
#36
  • Sep 20, 2005
  • #36
How much water?
If it's just a little bit, then I would say yes. If it was a lot, then it's something else.
98blackstallion
602
mtn home arkansas
Sep 20, 2005
#37
  • Sep 20, 2005
  • #37
its enough water to make the oil look cloudy.
98blackstallion
602
mtn home arkansas
Sep 21, 2005
#38
  • Sep 21, 2005
  • #38
ok guys im starting my redo of my headswap. Heads and cams are in and i just need to start the torque sequences on both of them. Im still alittle anxious as to see if this thing is gonna leak or not. Atleast now i have the stupid plugs in lol...which i think was the whole problem to begin with lol...i prolly didnt even need to tear this thing apart again. but oh well atleast i know what and how to do this now for future cam swaps and stuff.
Blev
1,295
So. Cal. V-Town
Sep 21, 2005
#39
  • Sep 21, 2005
  • #39
Keeping my fingers crossed for you, good luck
53BigDog
2,331
Palm Harbor, FL
Sep 21, 2005
#40
  • Sep 21, 2005
  • #40
damn you guys are al spooking me on mine, I'm right in the middle of it.
  • 3
  • 4
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
