  • SN95 4.6L Mustang Tech
PI Intake Adapter Plates
  • Thread starter Thread starter sneaky98gt
  • Start date Start date Oct 22, 2008
sneaky98gt
2,387
144
114
NC State University
Oct 22, 2008
  • Oct 22, 2008
So I am planning getting the PI intake and cams pretty soon to put onto a 98 npi. I've been looking around and deciding whether or not to get the adapter plates, and I believe that I'd rather have them, as a blower in the far future may be a possibility. And I figure I might as well go ahead and do it right now. Is there anywhere other than Livernois that sells the adapter plates? The Livernois kit is currently priced at $500. I can get the intake for a hundred bucks, so i figure that the plates can't be worth $400. Ideas? Or am I better off just using a bunch of RTV? Thanks.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Oct 22, 2008
  • Oct 22, 2008
just RTV it, it has nothing to do with the intake ports, only the water jackets, so you can still run boost, and not worry about blowing the intake gaskets, 400$ is a crazy price for those adapters, i have had my intake on for about 8 months now with NO problems
a tube of rtv is like 4$ bucks.......
and you will love the pi cams/intake swap
sneaky98gt
2,387
144
114
NC State University
Oct 22, 2008
  • Oct 22, 2008
so do I need to use the PI gaskets, or NPI gaskets in order to get the best seal/safeness?
Killa
1,006
56
49
Oct 23, 2008
  • Oct 23, 2008
im current using the adapter ( I think it 100 buck ), with PI gasket, after a year no complaint yet.
98COBRA281
1,348
30
59
Oct 23, 2008
  • Oct 23, 2008
use pi gaskets, so you only have to RTV 2 coolant ports,
if you use npi gaskets you will have to RTV all 8 of the intake ports
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 23, 2008
  • Oct 23, 2008
The reason the livernois kit is higher is because they shave the intake down so you can still have hood clearance and they supply the longer bolts needed so you can just bolt it on when you get it instead of having to hunt for longer bolts
sneaky98gt
2,387
144
114
NC State University
Oct 23, 2008
  • Oct 23, 2008
well, the longer bolts arent a problem for me, but will the pi intake not fit under the stock hood? or does it just not fit if you also use the adapter plates?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Oct 23, 2008
  • Oct 23, 2008
The Livernois kit modifies the intake. It will fit with the stock intake but if you have an aftermarket plenum or strut tower brace it will not. I bought some homemade pieces from a guy here but he doesn't do them anymore.
Killa
1,006
56
49
Oct 23, 2008
  • Oct 23, 2008
YES THE PI INTAKE WILL FIX UNDER STOCK HOOD FINE, EVEN WITH THE ADAPTER, USE THE SAME BOLT, NO NEED BUY A LONGER BOLT.
d98gt
4,505
59
204
SE Texas
Oct 23, 2008
#10
  • Oct 23, 2008
  • #10
HPS sells adapters for around $100 I believe so you could check into them if you aren't comfortable with the RTV.
sneaky98gt
2,387
144
114
NC State University
Oct 23, 2008
#11
  • Oct 23, 2008
  • #11
That's exactly what I needed to know. I'll take this into consideration, and thanks a lot.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
G
Supercharger Options 5.4 32V Intech
  • Germangazguzzler
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Apr 23, 2025
RaggedGT
W
Blue smoke..
  • Wicked_Rpm
  • Aug 11, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 14, 2024
weendoggy
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
