PI Intake Manifold Install Issue
97Vicious281
35
Atlanta, GA
How's it going guys. I've been doing the PI Intake Manifold swap on my 97 GT, and it has gone fine up until this point. I've got an issue getting the water pump nipple off of the back of the pump in the valley of the block. Here is a link to the install guide from American Muscle.
How To Install A Mustang PI Intake - Installation Instructions at AmericanMuscle.com
If you check out pictures 8 & 9 you will see the nipple that I'm talking about. I've got the new one ready to go, but I can't get the original out. I've tried to use a set of channel locks but that has only gotten it to the point of my having to cut a piece off of the end of it since it clamped down on it.
Any comments/suggestions would be greatly appreciated because this is the only thing holding me up from putting it all back together.
Thanks.
@WMBurns
Here are a few shots of it.
I couldn't upload more than 2 on here, but I added them onto my website under this directory: Index of /intake
97ViciousGT:
Mr. Burns is correct: use a small block of wood as a pad and tap the nipple out. Heat (propane torch with a small flame) or PB Blaster are good aids. That nipple has been in the same spot for 14 years. There is one, maybe two, o-rings on the nipple and they are probably dried out adding to the sticking problem.
Keep at it. You will get that little thing out of there.
HTH,
Chris
At the risk of stating the obvious (again), which way are you trying to remove it (towards the front or rear)?
It's a press fit, so likely some penetrating oil should be used. If you can get some Kano Kroil, this stuff really does everything it says. Even flows uphill. Highly recommend.
Penetrating-Lubricating Oils
The WEB site link is "404".
I am with these guys. From the pictures it appears that you are trying to pull it out on the valley side. It comes out the pump side. You may want to try to use a drive tool or a large screwdriver with a hose clamp on it to get it started as the tube portion appears to be weakened.. This would keep the tube from splitting and transfer the force to the rest of the fitting. Remove the hose clamp once you get it started and make the tube as round as possible - you do not want to scar the ID of the hole or you will have the potential for a leak.
I find it irresponsible for a company as big as American Muscle to put a write up on installing a PI intake on a NPI car without the use of adapter plates like the Livernois kit comes with , I think if American Muscle wants to sell PI intakes to guys with NPI heads then they need to have someone make adapter plates to do the install properly , install also mentions nothing about drilling and tapping for the 2nd coolant sensor
Here is the proper way to do it
http://www.livernoismotorsports.com/products/1996%2d1998-4.6L-PI-Intake-Adapter-Kit.html
Reactions: Firevalk01
Ahhh I didn't know it came
Out of the pump side. I'll give that a try tomorrow. Thanks for all the help.
This should take care of that issue for you. :)
Here is a little portion I wrote some time ago, for those that come across this in a search, since everyone is linking very helpful articles.
PI Intake Swap Checklist Install Help:
Excellent Intake Removal and Replacement Article
Intake Torque Sequence
01+ PI Intake Gasket* – YL3Z-9439-BA -(1 each for a total of 2) – or FelPro – MS-92121
96-98 NPI Intake Gasket - XW7Z-9439-AA
Alternator Bracket - F8AZ-10153-EA – 96-98 with PI Intake/Al. Crossover - (1 brkt)
Coolant Tube – XR3Z-18B402-AA - (1 tube)
Coolant Nipple – F75Z-8555-AA – (1 nipple)
Upper Plenum O-Ring – XR3Z-9L437-BA – (1 o-ring)
Thermostat O-Ring – F1VY-8255-A – (1 o-ring)
Water Pump O-Ring – F1VY-8507-A – (1 o-ring)
Stock or 180* Thermostat – 3L3Z-8575-AC (192*) or XL3Z-8575-AA (180*) - (1 t-stat)
Thermostat Housing Bolts*: N811011-S309
* - If installing a PI Intake on Non-PI heads use PI intake gaskets and you will need to RTV in a few spots to prevent leaks.
** - Optional
Before installing the intake, install the heater tube over new coolant nipple and bolt it to the back of the driver side head. Using a Windsor head (99-00) will require you to drill out heater tube bracket hole and use a larger bolt.
Tap PI intake - 3/8-18 NPSF with Pipe Thread. Same tap as passenger side coolant sensor.
Install intake gasket dry. Move all sensors over from NPI to PI manifold. Thread sealer on front two coolant sensors only.
Be easy on brass inserts with no more than 106 inch lbs (8 ft lbs.)
Install thermostat with spring pointing down and install thermostat gasket dry on top of the thermostat.
Install plenum gasket dry.
Gap and install spark plugs with a little antiseize on threads and torque to 13 ft. lbs.
1996-1998 4.6L PI Intake Adapter Kit - Livernois Motorsports
Actually those adapter plates throw off the injector timing and spray pattern since they move the injectors away from the original location. Best way is weld the corner of the NPI water outlet (what I do) second best is RTV with a PI gasket.
