  • SN95 4.6L Mustang Tech
PI swap question
  • Thread starter Thread starter 2wheelryder
  • Start date Start date Aug 29, 2010
2wheelryder
20
  • Aug 29, 2010
im sure this is a dumb question but ill ask it anyway becuase ive heard mixed answers... i have a 96 Gt 5 speed and i got a motor from a 02 Gt 5 speed for a swap. will i run into any issues using the 96 trans with the 02 engine? do i buy a clutch for a 96 or a 02?? is there even any diference as far as transmissions are concerned?
trinity_gt
3,125
81
99
Canada
Aug 29, 2010
  • Aug 29, 2010
Your current trans will bolt right up. You'll want the 2002 clutch as it's 11" versus the 10.5" in your car now. Make sure you replace the pilot bearing while you're in there.
The transmissions are different. The 02 will have had a Tremec TR3650. Your 96 should be a T-45. The 3650 is rated to handle more torque than the T-45. As well, the TR3650 from the 02 will have a different speedo pickup than the T-45.
2wheelryder
20
  • Aug 29, 2010
thanx! thats exactly the information i was looking for. im trying to get everything i need together so i can do the swap within the next few weeks. guess ill stick with the t45 for now and probably go with a tremec later
fast97gt
1,082
north carolina
Aug 29, 2010
  • Aug 29, 2010
you can also run the 96 flywheel and 96 clutch, i did and works absolutly wonderful
2wheelryder
20
  • Aug 29, 2010
my clutch needs replacing and my flywheel should be resurfaced so more than likely i'm just gonna go ahead and order an aluminum 11 inch flywheel and heavy duty clutch. get those rpm's up a little quicker
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 30, 2010
  • Aug 30, 2010
I may sound like a broken record but...Don't forget about the Speedometer.
The 1998 and older cars use a VSS sensor. The 1999 and newer use an OSS sensor. They are not compatible with each other.
Further, the number of teeth on the OSS wheel changed along the way. So transplanting a transmission from a 1999/2004 may have issues depending upon the exact combination (auto/manual/year).
FWIIW, I did the 10.5" to 11" flywheel/clutch upgrade. One lesson learned, the 11" clutch is much more expensive than the equivalent 10.5" clutch. If $$ is an issue, at least price compare to avoid surprises.
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
J
1996 v6-v8 swap
  • jujuonurmom
  • Oct 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2025
jujuonurmom
J
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
1998 v6 5-speed automatic transmission
  • Jude Thaddeus 1
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 21, 2026
