PIC needed, Keyless entry, please help
Hey guys, i really need a picture of the Keyless entry box that is mounted in the trunk. My car originally didnt come with KE, but i would like to convert to having keyless, without going aftermarket. I guess i should be asking, did all cars come pre-wired for this, or not? I fished around in the trunk, underneath the panels, and couldnt find any connectors.
Ive found a KE box on ebay, but dont want to buy it without confirming i can really pull this off
Thanks alot!
Jay
P.S.
Here is a E beer and a good lookin girl for helpin out a bro
heres what i have when i installed my keyless entry in my 95 stang...the item circled in yellow is the antennae wire that hooks into the box. The item circled in white is the wire harness that hooks into the keyless box, where its seen now its just plugged into a holder that holds the plug when not in use, you remove it from this location and plug it into the box. the red circled item is not used if i remember correctly.The black box you see the wire harness circled in white has to be removed and the box is secured to the back.
<a href="http://s43.photobucket.com/albums/e382/bill302/?action=view&current=trunklk.jpg" target="_blank"><img src="http://i43.photobucket.com/albums/e382/bill302/trunklk.jpg" border="0" alt="Photobucket"></a>
this is the keyless box inside the mounting box that you see in my trunk above. This is a view where it mounts on the backside of the box you will have and see in my trunk above..after you plug up the keyless box you will need the proper key fob and direction on how to program it is very easy...
<a href="http://s43.photobucket.com/albums/e382/bill302/?action=view&current=img8675qr2.jpg" target="_blank"><img src="http://i43.photobucket.com/albums/e382/bill302/img8675qr2.jpg" border="0" alt="Photobucket"></a>
well i looked again, and i dont have ANY of that big fat bundle that runs along the trunk pan in your picture, all i have is one small harness that leads to the tail lights/fuel pump, and thats it. So unless that bundle is hidden somewhere good, stock keyless entry is no longer in my books, dang.
