I am looking for a picture of the inside of the door shell, up where the door panel/belt molding sits on the top lip of the inside of the door shell.
My drivers side door panel will NOT sit down far enough. I have to push hard on the top of the panel to get the push pins to line up, and even after everything is installed the top of the inside belt molding sits too high. This happens with different door panels, and the belt moldings are properly placed on the panel. If I push it down it will sit where it is supposed to, but as soon as i let off pressure it springs back up.
I am thinking that maybe the top lip on the door shell is bent up too high, so I figured seeing some pics might help. Of course I did the pass side panel first, and really didn't want to take it off again.
Thank you.
Thank you.
