picked up some ASP aluminum pulleys... any tips?
Black95GTS
1,644
Marlborough, MA
Just picked them up off of racenet.net.
Anyway, I have access to an impact gun, so thats taken care of. I also know to put the car in gear and to loosen all the bolts before the tensioner. Is there anything else I need to know to make this easier?
Adam
It's simple, loosen the 1/2 inch bolts on the water pump and crank pulley. Use the impact gun on the alt. Remove the belt now. Take the stock stuff off and replace with the aluminum. Remember pullies require a cooler thermostat so if you haven't changed it yet now is a must.
