Jinx102672 said:You can try (I tried - no luck), but I highly doubt it. Another option is to check on Ebay.
My95.0L said:Damn I wish I'd found this a year ago! I didn't know they made replacement gears. Ford said I had to buy a whole new assembly. I wound up using JB Weld & a Dremel to replace the missing teeth
BTW, how much are they? I may buy the one you have left.
It controls the odometer and tripmeter only.MysticKeith50 said:does that gear just turn the odometer or the mph too?
HISSIN50 said:Jinx, I hadn't seen this thread until Paul linked to it on another thread. You did an outstanding job - rivaling just about any install article I've seen for a similar R/R. Fabulous pics and captions.![]()
Dan94GT said:Nice pictures and everything but you did way too much work. you do not have to take off the front piece and move any of the needles. Did you do white face gauges at the same time or something and just not add those pics?
allgo90 said:any more tips on removing that silver motor covering the gear. Im trying slightly but I dont want to brake the blue plastic!
I request the flip-top easy-open caps!Jinx102672 said:Just be very easy on it. It's kinda like a prescription medicine bottle (push down & turn). You may have to gently pry a small flatblade screw driver between the Blue plastic tab and the silver motor housing.
joesgt281 said:Jinx,
Mucho props on the fine writeup.
I did the install this weekend with the laptop and your pics right beside me the whole time.
Only thing I'll point out is that I was not able to get the headlight knob off by pulling that little keeper towards me. I struggled and struggled and finally managed to get it off (pretty easily) by pushing it toward the dash.
Just a little personal input.
Now I'll try it on car number 2 here as soon as I order another one!
Thanks alot.
Joe
Who knows, it's Ford we're talkin' aboutMakdaddymac said:do you need two of the gears or jus tone,for the fix?
Makdaddymac said:could i use vaseline for the grease,its all i have.lol.dont even got there guys? just thought vaseline would be a grease for it...
