I just installed a Summit aluminum radiator over the weekend. I think some people here were interested in seeing some pictures of this radiator installed in an SN95.
The radiator is SUM-380428 (19"x28"x3"). The fan is bolted to the flange on the top of the radiator, and I had to cut a few inches off of the top and bottom radiator hoses to get them to line up. I also bent the flange on the bottom of the radiator (the one facing the front of the car) so that the side tanks would sit flush on the rubber grommets at the bottom. The bracket for the overflow bottle bolted right back up with no modifications. I still need to clean things up a bit (neat up the wires, replace the zip ties with angle brackets), and I think I'm gonna have to cut a little off the radiator cover so I'll have access to the radiator cap.
I've been driving it around a few days and it's working great so far. The temp dropped from A to O. Anyway, enough jabbering, on with the pictures.
Joe
the radiator is in:
bolted up the fan shroud:
kinda tight next to the water pump pulley:
overflow bottle installed:
Joe
the radiator is in:
), and I don't have an AODE handy to check. Maybe someone else knows?
