Pilot bearing will not budge! Help!
  • Thread starter Thread starter _jb_
  • Start date Start date Apr 18, 2005
1 of 2 Next Last
_jb_
808
Michigan, Berrien County
Apr 18, 2005
  • Apr 18, 2005
hey everyone, I'm having trouble removing my pilot bearing. I've got the puller, and I've tried to pull it out, but it will not move. Tried to pry one side of the bearing out with a small screwdriver, just bends the edge of the bearing. I don't see any rust or anything formed around it, and I've run searches and I still can't get it out.
I'm taking the puller and putting it in the pilot bearing and it just won't move. I don't think the grease trick will work on this either. Am I suppsed to hammer in the center of the bearing first and then use the puller? It doesn't look like it would go in that way though.
Any help is appreciated. I'll be going to work soon and I'll give it another try tonight when I get home.
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 18, 2005
  • Apr 18, 2005
Many pilot bearings I've done in 5.0s have basically "welded" themselves into the crank. I've broken my puller many times (thank God for lifetime warranties) trying to get them out. I get them out usually with my air hammer, being very careful not to hit the crank
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 18, 2005
  • Apr 18, 2005
Only other thing I could see you doing is to go pick up a small torch and heating it up, then use the puller to whack it out.. You are using a slide hammer type puller, right?
67coupe
658
402
93
Huntsville, AL
Apr 18, 2005
  • Apr 18, 2005
What type of bearing puller are you using? One that forces the bearing out turning a large bolt or one that forces the bearing out using a slide hammer? If you not already using one, I highly recommend the slide hammer.
Mavrick
2,264
Collingwood, ON
Apr 18, 2005
  • Apr 18, 2005
Find a shaft slightly smaller than the bearing opening.. a spare input shaftw ould work perfect. Pack the hole with either heavy grease or SOAP (thats right, bar of hand soap), place the shaft into the opening and give it a whack with a hammer and it should pop right out.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Apr 18, 2005
  • Apr 18, 2005
You broke a slide hammer? Now I always use a slide hammer to remove the PB and never have any problems. You can also chisel the bearing out. Before I got a slide hammer I had to do this ... not fun and took a couple of hours. Don't hit the crank.
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 18, 2005
  • Apr 18, 2005
I broke the fitting for the pilot bearing many times.. the tip of it where it curves in... Broke it many times with hard to get out pilot bearings.
O
OWENMUSTANG
23
  • Apr 18, 2005
the grease/soap trick never worked for me....
slide hammer is the best. oh, an air hammer works,,,,,wear ear plugs!
Q
qtrracer
39
  • Apr 18, 2005
Soap method worked for me - car had 112K on it at the time. Trick is to seal that part where the soap would push out. I used a metric socket with an extension. Hardly anything escaped and the bearing just pushed out with each additional piece of soap added.
D
Daggar
3,902
#10
  • Apr 18, 2005
  • #10
The soap method usually only works when the bearing was going to cooperate in the first place. If you've already broken a slide hammer on it, you can pretty much forget getting it out with the grease or soap. I've never been able to get one the was stuck out with that method.
70lightning
205
in the basement makin stuff
Apr 18, 2005
#11
  • Apr 18, 2005
  • #11
First head butt some thing hard, when the adrenaline kicks in attack that mofo with a vengence untill you froth at the mouth and your eyes roll back in your head.
usally how I get things done.
D
Daggar
3,902
#12
  • Apr 18, 2005
  • #12
Then when the thing pops out, you reposition your fingers and joints back into their sockets. Apply bandages and some salve in the places where you left raw meat on the engine.
This is a good time to sit back, have a beer, and marvel at your own technical genius.
93 teal terror
971
62
69
Durham N.C.
Apr 18, 2005
#13
  • Apr 18, 2005
  • #13
I actually gave up on a motor swap because I couldn't get the bearing out (was going to put it in an auto) I didnt have an air chisel and tried everything to get it out, but it would still not come. Good luck
bryanrevans
296
Chicopee,Mass
Apr 18, 2005
#14
  • Apr 18, 2005
  • #14
I spent 2 days on it.I marked the cranks too much with air chisel so I went to autozone and temp loaned the puller w/hook bolt poper out tool thing!!!!!Worked finally
5.0alltheway
32
carolina
Apr 18, 2005
#15
  • Apr 18, 2005
  • #15
buy yourself a cold chisel(8.00),hammer the sides of the bearing race until you break it,start on the outer edge at the crank ,not on the crank,hammer in toward the center. once you break the race is all downhill.
_jb_
808
Apr 23, 2005
#16
  • Apr 23, 2005
  • #16
Thanks guys, but my dad got it out for me later that day when I was at work.
bryanrevans
296
Chicopee,Mass
Apr 23, 2005
#17
  • Apr 23, 2005
  • #17
Figures.Dads always figure s h it out.Good to go!!!!
_jb_
808
Apr 24, 2005
#18
  • Apr 24, 2005
  • #18
Yeah it turns out they gave me the wrong puller at Autozone.
V
v8only
2,378
22
49
Apr 24, 2005
#19
  • Apr 24, 2005
  • #19
simple laws of physics. the grease method will work. My father bailed me out of this too. he used a soft plyable clay and shoved it in the end of the crank, then shoved it into the socket and put an ext on the end so the grease won't come out. so long as your socket is close in size to the hold, it'll come out.
HISSIN50
34
129
Apr 24, 2005
#20
  • Apr 24, 2005
  • #20
hydraulics (grease method) are great.
1 of 2 Next Last
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
