Engine Pilot bearing
twohawks777@cox
112
23
28
I caint seem to get this pilot bearing any closer to fitting flush! Any thoughts? Is it close enough? Thoughts?:oops::rolleyes::cautious::confused:
Well. I took it out and checked if there were any burs or obstruction. There was none. I measured the old bearing and the new one . They were identical. I measured the orifice that the bearing sits is and found it to bottom out with bearing sitting not flush. The old identical one has been in there the same way for almost twenty years. Never had any problems. Anyone else had this experience?
FYI. Just a follow up. I took measurements of all the pilot bearings and they were all identical including the new Ford Performance one. None of them fit flush. The old one apparently didn't either and it had been installed for over 15 years with zero problems. I finished the job and everything works perfectly.
