Pilot bushing removal
  • Thread starter Thread starter CurlyA6
  • Start date Start date Nov 21, 2011
CurlyA6
47
Pacific Grove, CA
Nov 21, 2011
  • Nov 21, 2011
Does anyone have another method for removing a pilot bushing?
I read in the manual to pack the crankshaft cavity and pilot bushing hole with grease then drive a rod (matching the i.d. of the bushing) into the grease to force the bushing out hydraulically. In case that fails, is there another way I can get the bushing out without damaging it?
Only the very face edge of my bushing is worn, and if I can get it out cleanly I'd like to reverse it and reinstall it...so using a slide hammer to pull the bushing is not a good option. Is that okay, turning the bushing around and reusing it?
Thanks.
zookeeper
3,415
63
109
Rogue River, Oregon
Nov 21, 2011
  • Nov 21, 2011
I can think of no good reason at all for re-using a pilot bushing. They are so cheap it's not even funny and using a new one prevents possible headaches like noisy shifting, vibrations from wear plus the never-ending thrill of removing the trans to replace the $10 part you thought looked OK. Get it out however you like and toss it in the trash and don't look back.
CurlyA6
47
Pacific Grove, CA
Nov 22, 2011
  • Nov 22, 2011
Good advice. I'll yank and toss it today.
Thanks.
WTFO
53
Clarks-Vegas
Nov 22, 2011
  • Nov 22, 2011
I've used a Dremel tool with their cut-off wheels to get pilot bushings out in my Bronco IIs. Cut little hash marks as deep as possible then use a small bit chisel to chip it out piece by piece if necessary. Of course just have to watch out on the crank. Good luck!!
65coupe408w
192
  • Nov 22, 2011
I know it sounds strange, but I tried the grease method on my brothers stang once and it didnt work, so we resorted to bread, we manged to compact 2 whole slices into the small opening but sure enough it popped the bearing right out in the end...just another thought. Good luck!
Hack
1,945
Minneapolis
Nov 22, 2011
  • Nov 22, 2011
Grease never worked for me, but I have used a bar of soap in the same manner. It always works great. Just carve off hunks of the bar and stuff them into the opening until it's full. Then use a bolt and a BFH - it will come right out.
I actually bought a slide hammer specifically for pulling pilot bearings but that never worked very well for me either.
Edit: I would also recommend upgrading to the bearing version rather than using the solid bronze bushing.
WTFO
53
Clarks-Vegas
Nov 22, 2011
  • Nov 22, 2011
That's awesome!!! Was it white or wheat??
CurlyA6
47
Pacific Grove, CA
Nov 23, 2011
  • Nov 23, 2011
Hack,
I got lucky and the grease method worked for me. My short extension for the 1/2" drive ratchet was just a bit too small for the pilot busing hole, but a couple wraps of painter's tape made a nice seal and almost no grease weeped out. Bearing popped right out.
Shame, I wanted to try the soap or bread options. I'll keep that in my arsenal for next time.
I didn't even know there was a bearing option...I'll look into it.
Thanks.
Hack
1,945
Minneapolis
Nov 25, 2011
  • Nov 25, 2011
CurlyA6 said:
Hack,
Thanks.
Glad to hear it went well. Grease is a good material to use if you can because it cleans out very easily. More viscous materials take a bit more effort to remove.
Good idea using tape to get a tighter fit. I bought a bolt that was a little too big to fit and then ground it down little by little until it went in.
Yeah, Ford put bearings rather than bushings in the 80s and newer manual transmission cars, so they are very common. Any parts store should have them, depending on the engine you are working with.
CurlyA6
47
Pacific Grove, CA
Nov 26, 2011
#10
  • Nov 26, 2011
  • #10
I didn't know that (all my experience has been with '67-68 Mustangs). I've got the O.D and I.D. written down...off to the parts store to see if they can help me out.
Does the bearing come pre-lubed and sealed, or is there any tricks I should know to lube the bearing without ruining the clutch plate?
Thanks.
John
Hack
1,945
Minneapolis
Nov 27, 2011
#11
  • Nov 27, 2011
  • #11
Thanks.
John
Unless you have a top notch local parts guy you will probably want to ask for a pilot bearing from an '89 Mustang GT. Even the worst parts monkey should be able to locate it with that info. Then you can check and verify it will work with your crank/transmission combination.
They come pre-lubed. Just press it in.
CurlyA6
47
Pacific Grove, CA
Nov 27, 2011
#12
  • Nov 27, 2011
  • #12
Great, I'll start with asking for the pilot bearing for a '89 Mustang GT and will bring the old bushing for size comparison.
Much appreciated suggestion, thanks.
CurlyA6
47
Pacific Grove, CA
Nov 29, 2011
#13
  • Nov 29, 2011
  • #13
Hmmm, local partsdude had different dimensions (O.D. and I.D.) in his book for the '89 GT Mustang pilot bearing, but Mustangs Plus had what I believe to be the correct one in stock. I'll let you know how it works out.
Thanks.
Hack
1,945
Minneapolis
Nov 29, 2011
#14
  • Nov 29, 2011
  • #14
Thanks.
Please post the results. It will be helpful for others in the future looking to do the same thing.
Thanks,
Mike
CurlyA6
47
Pacific Grove, CA
Dec 1, 2011
#15
  • Dec 1, 2011
  • #15
Right-o. Here's what I found. Mustangs Plus electronic catalog, page 266, part number 7583 "65-73 Mustang Roller Pilot Bearing." Sort of a sketchy description, so I called and asked Kris to pull one off the shelf and measure it with a micrometer. It is 1.38" o.d. and .675 i.d., approximately. Sold for $17.95 and arrived the next day. I laid it on the old bushing (on my workbench) and eyeball calipers indicated a perfect match in three dimensions. I slipped it on the tranny input shaft...perfect fit. I installed it in the crankshaft by tapping on a 1 1/16" socket protecting the bearing. Easy installation. I've now got the tranny in and awaiting one last part before testing the bearing, but all indications are good.
Thanks again for all the help.
Hack
1,945
Minneapolis
Dec 1, 2011
#16
  • Dec 1, 2011
  • #16
Is this a 289 with a 4 speed toploader application or a 390, 302...? I'm sorry if you already said and I missed it.
CurlyA6
47
Pacific Grove, CA
Dec 4, 2011
#17
  • Dec 4, 2011
  • #17
Well...I thought it was a 302 with a 4 speed Toploader, but now find the block number is a '69 351W. Crazy.
Kelley97
18
GA
Jan 18, 2012
#18
  • Jan 18, 2012
  • #18
I recently replaced the clutch in my '90 mustang lx. The pilot bearing everybody had listed as the correct one was too big on my transmission shaft. The one in the car was like .59. Think the stock one is like .63 or .67. Found one at napa. Anybody seen one this small on any other mustangs?
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
C
Progress Thread 2004 Comp Orange GT
  • ctandc
  • Jun 26, 2023
  • 2 3 4
6K
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
ctandc
C
Pilot Bearing Removal
  • Black1987
  • Sep 11, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 19, 2021
chrlsful
C
Front control arm bushing replacement
  • GT80
  • Dec 17, 2018
10K
Fox 5.0 Mustang Tech Mar 1, 2019
GT80
D
66 Mustang, New T5 conversion engage/disengagement ISSUE! HELP!
  • Desert Dwella
  • Mar 12, 2019
4K
Classic Mustang Specific Tech Mar 31, 2019
General karthief
