Pinging under light acceleration?!
Xcessiv
187
Hi.
About three months ago, I installed a Predator tuner. I use 91 octane fuel and everything is fine... Most of the time!
When driving the car in the morning, the engine "seems to pings" under light acceleration until it gets warmer. How can it ping at more or less 25% throttle? I always thought that knocking happens under heavy acceleration.
Could it be another problem? I've never heard a car pinging so I can't be sure.
Thanks in advance for your help! :hail2:
Best regards
twogts4us said:
Are you saying it doesn't ping at all when it's warm? Is this problem just recent, as sgarlic pointed out, maybe related to a bad tank of gas? Can you get 93 oct?
It's not pinging at all when it's warm, running pretty strong (13.2 @ 105 at the local dragstrip).
Yes the problem is recent, but it's not recent enough to be a bad tank of gas. I refilled it at least 10 times. Could a really small mid pipe leak cause this "tractor" sound in the morning? I'm really not sure if it's pinging, especially considering that it also happens on really light acceleration (10-25%).
Did you try some 94 at Petro? I have Predator tune also and I thought 91 would do since it didn't ping. Then, I went to the track and heard slight pinging at 6000rpm. Since I ran 94, no more pinging whatsoever.
Also check if it's your fuel filter.
