Pinging
  • Thread starter Thread starter slow88stang
  • Start date Start date Mar 28, 2004
slow88stang
144
St Albert AB
Mar 28, 2004
  • Mar 28, 2004
Maybe a stupid question but what does pinging sound like. My car makes a wierd noise when accelerating but i dont know what it is.
dastang2
2,020
tx
Mar 28, 2004
  • Mar 28, 2004
it sort of sounds like a high pitched knocking noise or rattleing.
slow88stang
144
St Albert AB
Mar 28, 2004
  • Mar 28, 2004
well i guess the sound im hearing isnt that. i think its air screaming through my throtlle body., but ive never heard this in any other car. It really quite loud, i can hear it over the exhaust and stereo. my exhaust is louder than the average and the stereo will overpower so i think thats saying its pretty damn loud. any ideas whay that would be happening?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 29, 2004
  • Mar 29, 2004
If it sounds like a bunch of marbles ratting in a coffee can, its pinging.
Pinging is caused by a number of things:
1.) Hot spots in the combustion chamber such as carbon deposits from high mileage or excessive oil consumption.
2.) Wrong heat range on the plugs.
3.) Too much initial spark advance.
4.) Lean fuel mixture.
Lean fuel mixture breaks out into several sub categories:
A. Vacuum leaks
B. Air entering the intake without passing through the MAF
C. Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D. Leaking exhaust gases from EGR valve at WOT.
E. Clogged fuel injectors.
F. Fuel injector wiring problems causing injector not to deliver rated flow.
5.) Computer problems: (computer problems are not common like sensor problems)
A. ROM has bad data in fuel or timing table. This should also set a code in the computer.
B. Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one.
Have you dumped out the codes?
Here's the link to dump the computer codes with only a jumper wire and the check engine light. I’ve used it for years, and it works great.
See http://www.batauto.com/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/article...c-iv_codes.html
88stangmangt
2,332
Stafford,VA
Mar 29, 2004
  • Mar 29, 2004
could be a exhaust leak.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 26, 2026
nicholase
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
