My 95 cobra pings under hard acceleration running 93oct. and timing at 13deg. Something wrong there? starts pinging at around 4K. What do you guys think i should do? i know stock is 10, and i do remove the spout before i change it.
My problem turned out to be the distributor shaft. the bearing was so worn out that the reluctor wheel was smashing into the PIP sensor and thus damaged it. Fixed the dizzy, replaced the PIP and was good to go.
maybe your HB has slipped and your not really at 13 deg.
what's the water temp when it does it. Mine would ping like that after sitting in traffic on a hot day
I have 10.33-10.6 comp on a iron head gt40 motor, run the stock rad., live in a area that gets 100-110 temps with 90+% humidity in the summer and have ran 32-33* total timing (28 is stock IIRC). I have even ran 91 with no issues at 32*. Datalogged temps and autometer guage show 192-194* as well. 20-30* colder than stock will help greatly to stop ping.
First off, it's common knowledge that GT40 heads with their different combustion chamber design don't lend themselves to detonation nearly as bad as their E7TE counter parts.
Second, you have tuned your car, so you can't really say you're getting away with x amount of timing when you have tuning ability. For instance, you have to be able to tune the car somehow to adjust the fan turn on temps. I'm not sure how you modified your fuel and spark tables, but to my understanding it is one of those values that is programmed into the T4MO computer that promotes pinging in the first place.
So obviously if you combine a tuning device with a "less likely to ping" cylinder head, of course you can run more timing and be safe. As it stands, If I set my timing to anything over 10* it'll ping like crazy! And I do have a new balancer and just about everything else as well.
