Pioneer balancer install tomorrow!!
somersdp
191
WPB,Florida
Just wondering if there is anything I need to do to install this balancer in the morning. I know that the balancer needs to lose the 15/16" retaining nut and be pulled with a puller. Do I grease the crank before instalation or anything? should I just pull off the old one and put the new one on and replace the pulley? Just checking if there are any tricks or anything I am forgetting? PLease let me know. Thanks guys. Should the pioneer balancer dampen better at high rpm's than the stock harmonic balancer?
Thanks man, I know it is pretty cut and dry, but I have to cover my bases ya know. PLus I was wondering If i grease the crank or put oil on it. Anyone else can give me suggestions if you have something else maybe you have run into when replacing one!!
I think I will try some antisieze on the actual crank shaft and then put some lithium grease inbetween the seal and the balancer......is that right? Easy job , I just wanted to check with you guys first ya know.
