piston isnt going in caliper nicely
myg-
71
i was changing my brakes but my piston wont compress into my caliper when i use my c clamp on it... i cant put on my new brakes damnit!
this is my first time changing it on this car, im doing it the same ive done on my past vehicles.. are 96 gts different with this or something?
or is my caliper just messed
No, the brake fluid pushes the piston out normally, the screwing part is because the e-brake uses a screw type rachet mechanism internally. This is common for all vehicles that use an intergrated parking brake in the caliper.
Trust us...rear calipers screw in. Front calipers press in.
you have to screw the rear pistons back in. if you force them in with a c clamp you can cause catastrophic damage to the internal workings of the caliper. just go to a parts store and borrow the tool or buy your own. i have the $150 one from MATCO. but you can buy the same thing from harbor freight for like $30. whatever people tell you dont use hte cube one, it will make you want to kill yourself. i used one once and threw it away.
The rear calipers screw in.
You can borrow the tool to do this at AutoZone for a $40 deposit. You can buy the tool to do this at Harbor Freight for $40.
It looks like this:
i used my regular press in piston tool (9 bux at pep boys) and locking wrench.. just turn with the wrench, then press in, turn, press in and so on untill you cant get a grip on the piston with the wrench..then u kno ur good.. not really ghetto, and really easy to do.
It looks like this:
I got that kit from AutoZone many years ago and I loved it so much I kept it. But back then the deposit was only $20. Too many people must've followed suit. :)
