dolfan87 said:
Well I hate to argue with you, but what in the world are you talking about? Nylon plugs?
The rod end is bushed with a bronze bushing, and the piston pin is held in place with spirolocks at either side of the piston. There is no nylon plug anywhere.
It is a WELL known fact that friction is reduced in a floating pin situation. This is why turbo charged, nitrous, and super charged engine builders strongly recommend using the system.
A TRUE full floating piston pin is NOT held in place in the piston pin bosses with spirolocks, or anything else. The pin FLOATS in and out and is prevented from causing damage to the cylinder wall by nylon,(or now-a-days teflon coated aluminum), plugs. Does plug contact the cylinder wall?? Yes.
Spirolocks are unique to the automotive industry as far as I know, and yes, they are a pain to get installed, but the pin is not allowed to travel past the spirolocks
WEAR is reduced in a full-floating pin design as the pin is allowed to rotate within the piston and connecting rod bosses, and the same radius of the pin is not continually subjected to the impact load of combustion, and the applied load of reciprocation.
The assembled tolerances of full-floating pins are obviously greater than semi-floating, or press fit, which is endorsed as a allowance for piston thermal expansion from forced induction or nitrous. That is why engine builders favor the design for forced induction/nitrous applications.
Why would you get a easier spun rotating assembly as you mentioned?
The angular motion of the piston and rod assembly around the pin is not impeaded from a press fit anymore than from a semi, or full floating
Remove the piston rings, and yes, you'll get a easier spun rotating assembly, but not from piston pin type design
As mentioned, piston and cylinder removal and replacement is much easier and can be performed in the field, and the wrist pin can be removed, and the piston and cylinder assembly lifted from the engine without every removing the piston from the cylinder, or unseating the rings. The reverse is true as long as the rod bushing has not been elongated or scored beyond serviceable limits. Of course this does not apply to the V8 configured engine, as the cylilnders are not removeable.
The full-floating piston pin has been used as early as the late 1800s
