Pistons are stuck
  • Thread starter Thread starter 85ragtop
  • Start date Start date Sep 20, 2006
85ragtop
BTW, I like dudes.
475
123
NC
Sep 20, 2006
  • Sep 20, 2006
I have an engine as given to me. I was told that it was kept in a barn away from rain. Well I go to take the heads off (which I am not going to use) and the freakin cylinder walls are rusted badly. So I cleaned them up as best I could, took of the rod caps and tried to tap the pistons out. The stupid things won’t move. I have done this several times in the past and never have I had this much trouble. Can someone help me with this?
blownlxvert
48
endicott n.y.
Sep 20, 2006
  • Sep 20, 2006
spray a little rust penetrant down the cylinder and let it do its thing.
RYC CUKR
1,437
Orlando
Sep 20, 2006
  • Sep 20, 2006
put some marvel mystery oil in the cylinders and let it set for a bit and see if that frees them up.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 20, 2006
  • Sep 20, 2006
Either penitrating oil or regular oil liberally applied to the tops (and bottom) of the pistons.
You'll need to let the oil soak the rings for about 1 day and then rotate the motor and hit the bottom of the pistons with an oil can (if possible)
85ragtop
BTW, I like dudes.
475
123
NC
Sep 20, 2006
  • Sep 20, 2006
Thanks you guy. I put some PB blaster in there last night. I see if it worked.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 20, 2006
  • Sep 20, 2006
ATF is also a good oil to try to free up pistons.
5ive.oh
195
Rocky Mountain House, AB
Sep 20, 2006
  • Sep 20, 2006
Red vinegar. Sounds strange but I used it on an old dirt bike engine.
Henceforward
The Avatar Master
485
  • Sep 20, 2006
85ragtop said:
Thanks you guys. I put some PB blaster in there last night. I'll see if it worked.
I would have used try PB blaster too.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 20, 2006
  • Sep 20, 2006
That Seafoam Stuff may work too.
dastang2
2,020
tx
Sep 20, 2006
#10
  • Sep 20, 2006
  • #10
somebody said it already, automatic tranny fluid works great on this. i once locked a motor up while showing it to a potential buyer. i put a new dizzy in it and a jammed it in there without making sure the oil pump rod lined up. i reved it a few times and it quickly locked up. poured that in the cylinders and it sat overnight and worked.
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
G
Turning a 4.6 into a 5.4
  • Green mustang
  • Jun 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2025
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
