pistons tap heads..
  • Thread starter Thread starter stangster50
  • Start date Start date Mar 24, 2008
stangster50
129
cranston ri
Mar 24, 2008
  • Mar 24, 2008
ok, i figured i would start a new thread, since its a different topic... if i just rest my gt40x-303 heads on my block, and spin the crank, i can hear each piston tap the head.. with no headgasket..
is that normal, to be that close.. or will a headgasket stop that? i really dont want to hurt my new heads..
PUNISHER RACING
1,124
FORD CITY, PA.
Mar 24, 2008
  • Mar 24, 2008
a typical h/g is only .040 thick so ?
Rick 91GT
Mustang Master
95
99
PA
Mar 24, 2008
  • Mar 24, 2008
Wouldn't be totally out of the ordinary, that basically means you have .040 quench if you use a .040" head gasket. I am assuming the piston are 0 deck or slightly above the deck of the block?
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Mar 24, 2008
  • Mar 24, 2008
Clay the heads and see how close you really are. Use a HG as well
347HO
462
Seattle
Mar 24, 2008
  • Mar 24, 2008
To find your piston to deck height, just mic from the tops of your pistons @ their centerline with the pin to your block using a straight edge block. Whatever "in" the hole you are, add that to your quench. Whatever "out" of the hole you are, subtract that from your quench. As posted previously by many... your quench is with the gasket you're using in it's compressed state.
stangster50
129
cranston ri
Mar 24, 2008
  • Mar 24, 2008
whats too close?
Fast63
717
  • Mar 24, 2008
I would say with the gasket you shouldn't run any tighter than .035, but I think you can run as close as .030 Use the straight edge method described by 347HO
Also, it can be normal for the piston to come out of the hole, it just should not come out a lot. Mine stick out .003 inches at top dead center. My head gasket is .044 compressed, so I'm getting a .041 quench.
stangster50
129
cranston ri
Mar 24, 2008
  • Mar 24, 2008
ok. ill have to measure.. i have the felpro 1101-1's? that sound right? i unno... but crushed, is .041 i believe.
thank you.
347HO
462
Seattle
Mar 24, 2008
  • Mar 24, 2008
thank you.
I have "zero" deck and I do use fel-pro 1101-1 gaskets.
stangster50
129
cranston ri
Mar 25, 2008
#10
  • Mar 25, 2008
  • #10
sorry.. not sure i understand this too well.. can you better explain how i can get exact measurements? i put a straight edge across the deck/piston, and the piston does come out of the bore a bit.
also... my felpro 1011-1 gaskets say they are .041 thick... is that compressed thickness?
88stangmangt
2,332
Stafford,VA
Mar 25, 2008
#11
  • Mar 25, 2008
  • #11
.100/.80 is the min on valve clearance.....
You also didnt mention what kinda pistons,cam?? all important factors...
347HO
462
Seattle
Mar 25, 2008
#12
  • Mar 25, 2008
  • #12
Since your piston is out of the hole, measure from top of piston to the block from the pistons centerline with the pin using a depth mic.
You can also measure your piston rock by measuring the inboard or outboard piston edge while pushing down firmly with your finger the opposite side your measuring, then push firmly the same side your measuring, add them, then divide by 2.
It works and it will tell if anything is screwy going on.
If your block has not been "square" decked, then it's possible your measurements will vary by .002" to .010" from cylinder to cylinder.
It's interesting you've opted to build and engine with the pistons out of the hole... experienced engine builders find themselves dealing with many clearances which can get first timers and novices into trouble without even knowing.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Today at 1:24 PM
horse sence
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
