plastic gauge clearance
jrod92
66
i just plasti gauged my rods and they came out to .076mm the smallest measurement on the plasti gauge. i was wondering if this is good or bad? my problem was when i torqued all the rods it would not spin if the 4th cylinder was torqued all the way. im hoping its just a bent rod. thanks
I had that happen to me when i was building an engine and thats what it was a bent rod.
Rod Bearings......................Michigan 77 #CB 676 P (.002"-.0025")
this is the specs on an engine assembled by edelbrock
.075 sounds a little loose..If I remember correctly I was shooting for .0022 to .0025..some one else may need to correct me on that..
Not related to your problem, when I built my 1st motor I put the thust bearing in the back..I took it too the machine shop cuz I could figure out what I was doing wrong..the machine shop guys had a good laugh..
There's something wrong jrod92. Your clearances are way too wide. Also check to make sure you don't have that #4 cap flipped or that the piston wasn't pressed on the rod backwards. The tapered side of the rod bearing needs to face outward to the crank.
