I have a 65 K-Code with what I believe to be the original motor rebuilt to original specs. I want to give it a boost without doing anything exteme so I can go back original if need be. I have a Holley 650DP (4777) and a Ford Hi-Rise manifold, similar to the Cobra intake used by Shelby on the GT350. I don't want to screw with the original heads, so I'd like to try a set of Powerheads with the Holley/Cobra induction combo, and a set of Doug's Tri-Y's. Assuming the cam is a K-Code cam, my understanding is that the specs are:
Intake: 0.477" Lift with 0.022" Valve Lash with 1.6:1 Rocker Arms
Intake Opens 25 Degrees BTDC and Closes 70 Degrees ABDC, 275 Degrees Duration
Exhaust: 0.477" Lift with 0.022" Valve Lash with 1.6:1 Rocker Arms
Exhaust Opens 73 Degrees BBDC and Closes 22 Degrees ATDC, 275 Degrees Duration
Lobe Centers is 114 Degrees.
I got this off the K-Code site and it's supposed to be from the company that ground the original K cam.
Can you tell me if you think this is a good combo? The car supposedly makes 271hp is stock form, and mine runs pretty strong so I have no reason to doubt it. What do you think my gains will be? Also, anyone have any idea if the larger valves in the Powerheads will crash my pistons? I have no idea if the pistons have valve reliefs, I would assume not.
