  • 1994 - 1995 Specific Tech
Please HELP ASAP
  • Thread starter Thread starter allenpark94gt
  • Start date Start date May 29, 2005
A
allenpark94gt
196
allen park
May 29, 2005
  • May 29, 2005
My car has been dying randomly lately so i replaced the stator in the distributor since i read about a lot of ppl having the same problem and that fixed it...anyways...I removed the distributor, replaced the stator, now I cant get the car to start. I found TDC on #1, installed the dist. with rotor facing #1 and it still wont start....any ideas?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 29, 2005
  • May 29, 2005
PLay with the dizzy move it left some try to start if not move the other way. Seems like your timming is just way off.
rio95
829
Grand Rapids, MI
May 29, 2005
  • May 29, 2005
Are you sure the battery is strong enough and did not die for some reason? Also, maybe the starter is junk.
A
allenpark94gt
196
allen park
May 29, 2005
  • May 29, 2005
well it was running yesterday before i removed the dizzy.
just trying to figure out what i did wrong so it wont start now
yellowstang1994
338
  • May 29, 2005
Make sure everything is connected. I know that sound stupid but I left that one connector that has your RPM wire on it and my car wouldn't start. I recommend any time you change the distributor to check it with a timing light also. Even if you are accurate with putting it in back the same exact way I'd always double check it. But even so, it should run even if the timing is off. Just double check to make sure everything is connected is all I know what to say. Good luck!
HISSIN50
34
129
May 29, 2005
  • May 29, 2005
are you sure you are at TDC on the compression stroke on #1? one will feel air move out of the spark plug hole on the exhaust stroke also, and the car may or may not run being out of phase like that (it would run like poop if it even would catch).
good luck.
A
allenpark94gt
196
allen park
May 29, 2005
  • May 29, 2005
didnt think of that...I'll try it out tomorow and see how it goes...
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
