Quick question: I want to buy a shifter that will fit in the center console of my '88 fox body. The transmission is a c4 with a reverse pattern manual valve body. I found one on Summit for a forward pattern but that’s all I could find that is made specifically for a fox. Can anyone direct me as to where I can find a shifter that will work? Also, if no one makes a shifter for a c4 reverse pattern shift (specifically for a 87-93 fox) which other shifters will work without messing up the center console (if any)??? This is the first time I will be using a c4…so I am clueless. Thanks a lot to anyone who responds.
