Please Help/Clutch cable problems!!!!!!!
  • Thread starter Thread starter Brett88lx
  • Start date Start date Oct 1, 2006
Brett88lx
65
  • Oct 1, 2006
Thank you in advance to anyone with answers.
I just got finished putting in my new adjustable clutch cable, firewall adjuster, and quadrent(with only one hook).
The quadrent and firewall adjusters are both from UPR but my adjustable cable is of a differant brand(I think)
Everything went in easy(quadrent looks perfect but rubs a little on some plastic shroud) but there is still SO MUCH slack in the cable even after screwing out the firewall adjuster all the way(counter clockwise) and adjusting the cable near the clutch fork.
Do I have to use the stock rubber piece as well as the firewall unit??!!!!
Is my cable the wrong length???
Any help would be much appreciated!!!!!!!!!!!!
bob331T76
76
so cal
Oct 1, 2006
  • Oct 1, 2006
change your quadrent or cable, get the 3 hook quadrent works wonders.
HISSIN50
34
129
Oct 1, 2006
  • Oct 1, 2006
I run a UPR single hook quad and UPR FWA and stock cable and it's fine. Many adjustable cables are indeed longer (for proprietary quadrant/cable combos).
You should not need the rubber grommet with the FWA (I have one bud who does run both to compensate for a stretched cable however).
Do you have a stock cable to toss on and see how it does? Was the new cable compared to a stock cable for overall length?
What is the quadrant rubbing exactly? It should not rub anything.
Good luck.
V
v8only
2,378
22
49
Oct 2, 2006
  • Oct 2, 2006
the 3 hook quadrant blows chunks. the hooks are at different angles, and it'll cause it to engage way to high up, and still have too much slop on top of the pedal.
As hissin mentioned, that adj cable is longer, I'd try swapping in your stock cable.
Brett88lx
65
  • Oct 7, 2006
Thanks people, I really appreciate all your help.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
V
Drivetrain Clutch Cable too Short?!
  • vpap1
  • May 9, 2023
3K
Fox 5.0 Mustang Tech May 23, 2023
vpap1
V
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
7K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
