Please Help...Electrical Problem
  • Thread starter Thread starter limppimp
  • Start date Start date Mar 18, 2006
L
limppimp
149
  • Mar 18, 2006
I have done some searching on this problem and cant seem to get a clear answer. My car battery keeps draining when the car is turned off. When it sits over night it is completely drained the next morning. I had the alternator tested and it was fine. This is also my second brand new battery. I hear you can hook up a multi-meter and pull fuses to find out which circuit is draining. How exactly do you do this? I am a beginner when it comes to using a multimeter and electrical problems so I need specifics on everything. Thanks!
n8rsk8r
TwiLight zOne!!
Mar 18, 2006
  • Mar 18, 2006
is there any aftermarket stuff you have on your ride?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 18, 2006
  • Mar 18, 2006
Typically it is something draining the battery. Small things like glove box or courtesy lights are often the culprits. If you have an aftermarket stereo or alarm system, it is also suspect.
The ideal method is to disconnect the positive terminal, and connect a Digital Multimeter (DVM) between the positive terminal on the battery and the positive cable. Set the DVM on a low current scale of 2-5 amps if it doesn't auto range. Watch the current draw, and then start pulling out fuses. When you see a sudden drop in the current, that circuit is the likely culprit. Note that the computer, radio & clock will draw less than 1/10 amp to keep the settings alive.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf. You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
L
limppimp
149
  • Mar 18, 2006
OK here is what I have done:
I pulled each fuse and put a DVM where the fuse was. I set my DVM to read amps at 200 micros. Two things really stuck out. My [Air Bag System] is drawing 106.1 and my [Brake on/off (BOO) switch, Electronic Flasher] is drawing 68.3 amps. Are these normal?
L
limppimp
149
  • Mar 18, 2006
By the way my airbag flashes this code
34 | Low resistance in driver air bag circuit | L |
Its been doing it for about a year now. But I never had a problem witht he battery until now. Could that be the problem?
Saleen0679
876
24
49
Yakima, WA
Mar 18, 2006
  • Mar 18, 2006
Anything you pick up on the microamp scale is going to be negligible and would not drain your battery overnight. Put all your fuses back in and connect the meter between your battery and cable as mentioned in JRichkers post to see what the total current draw of the car is and try to narrow it down that way by seeing which fuse(s) cause the most drop.
J
JRPony
83
Las Vegas, NV
Mar 18, 2006
  • Mar 18, 2006
Are you sure its not milliamps? 106mA and 68.3mA are both huge draws. BTW, just a reminder, make sure the key is off when checking the current draw.
J
JRPony
83
Las Vegas, NV
Mar 18, 2006
  • Mar 18, 2006
Low resistance = shorted circuit. Could be your problem.
L
limppimp
149
  • Mar 18, 2006
Well it has the symbol for micro on it. (the u looking symbol) I had it on 200u.
I beginning to think the air bag might be the problem. I need to fix it anyway. Any idea on how to fix that code 34?
L
limppimp
149
#10
  • Mar 18, 2006
  • #10
and yes, I did have the key off.
L
limppimp
149
#11
  • Mar 19, 2006
  • #11
bttt
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
