  • 1994 - 1995 Specific Tech
PLEASE HELP FAULT CODE 181 ,189 showing in test
  • Thread starter Thread starter robby94gt
  • Start date Start date Jul 7, 2005
R
robby94gt
  • Jul 7, 2005
PLEASE HELP CODE 181 189 showing in test
It reade 181 fuel sestem at rich adaptive limit at partial throttle / system lean
189 says same thing fuel sestem at rich adaptive limit at partial throttle / system lean
i was wondering if anyone knows what i can do to correct this problem the car is not preforming very well mostly at takeoff it smells strong also
any help or ideas i will be most greatful for
Thanks Rob
94-302-vert
1,947
NE CT
Jul 8, 2005
  • Jul 8, 2005
Could be the EGR. My car was spitting out this code for the longest time after I had changed the O2, etc. Blocked off the EGR the other day and my CE light went off...
bard
Frisco, Tx
Jul 8, 2005
  • Jul 8, 2005
If it thinks its running lean yet you smell raw fuel then the most likely culprit are dead O2 sensors.
R
robby94gt
  • Jul 9, 2005
Thank you i changed the air filter and oil checked for vac leaks and when i ran codes again i got nothing seems to be running better i checked again and still just showing 111 oil presser gage seems to be at a different spot every time i start the car sometimes on the M in the middel and sometimes on the N of normal never shows danger but wondering if it was bad gage or sending unit or pump and would the code reader pick up any of those problems thanks for any help Rob
bard
Frisco, Tx
Jul 9, 2005
  • Jul 9, 2005
It might take a while to relearn to the rich condition if you cleared the codes. The funky gauge sounds like a grounding issue.
R
robby94gt
  • Jul 20, 2005
thanks guys for the help this place is great
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
F
Running rich with codes,
  • FiveOhGabe
  • Oct 5, 2023
2K
1994 - 1995 Specific Tech Oct 6, 2023
FiveOhGabe
F
F
Running Rich (codes included)
  • FiveOhGabe
  • Aug 7, 2023
1994 - 1995 Specific Tech Aug 9, 2023
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
