PLEASE HELP!!!! Overheating still!!!!
getnasty
Alright guys. I spent all day replacing the intake on my car because some ass decided to crossthread one of the thermostat housing bolts(behind the water pump). any ways I replaced the thermostat because my car runs beetween the N and O in normal. when sitting still it runs really hot and if I get going about 60-65 in cools down to almost halfway..WTF is wrong? Dosent seem to be the headgaskets because It dosent seem like im loosing coolent and it dosent smoke.. Im lost now maybe its the rad? coolant is moving in the rad while running so I assume its not the water pump. is there any way to test the water pump? PLEASE HELP!!!!!!
If you are hot while stationary and cooler when moving at speed the problem is most likely insufficient airflow.
What fan do you have?
Are you using the stock clutch fan?
It may be time to move to an e- fan.
jason
I had the same issues...first fix was a replacement fan clutch. I think it set me back $45 at the part store and took 30 min to swap it in for the old one. That is likely your issue if you are hot at idle but better when moving.
If that doesn't help, you COULD take it to a shop and have them pressure check your system, see if there are any non-obvious leaks. That would be pricey though.
If you have the stock water pump pulley (or all stock pulleys), you could put it back on and just get a new belt that fits (use string to get a fairly good estimate).
I ended up replacing the radiator with an OEM piece and upgraded to a high flow water pump to fix my cooling issues.
In a pinch, you could try some Redline Water Wetter coolant additive...it generally helps drop temps at least 10 degrees.
Good luck.
Another fan vote. You can get a metal FAL fan blade if your plastic one is cracked up. I chose a HD thermal clutch because it's often triple digits here.
Good luck.
Fan shourd is still in place.. the stock fan has small chunks missing on the ends of the blades.. can I get away with running a metal fan without a fan clutch? get a 2 inch spacer and a metal fan. the auto parts store wants $70 for a new clutch.
Currently I am using a metal fan and spacer. I think I used a 2.5" spacer though.
jason
I used a flexlite fan and a spacer like Vristang. Worked great but sounded like a WW2 plane. Decided to get a new clutch, stock plastic fan, lower temp thermostat and a cobra grille insert. Stays relatively cool now. Do agree about the insufficient air flow.
Heh, even my stock plastic fan with the new clutch is loud...but as my exhaust continues to get louder, the fan noise gets covered up...and if I get the car running again, I am betting the blower will be a bit louder than the fan.
